Courant Number Limit, CFL criterion
Old   July 28, 2009, 17:52
Default Courant Number Limit, CFL criterion
Barath Ezhilan
barath.ezhilan is on a distinguished road
Hi All,
I am currently simulating vortex breakdown in a conical diffuser and am doing unsteady simulations using transientSimpleFoam and LAunderGibsonRSTM model.
I have a doubt. The generally suggested criteria that CFL<1, is it the Courant Number mean value or the max courant number value???
I have a mean Courant Number of close to 0.13 and Maximum Courant Number of close to 7.
(Courant Number mean: 0.130184 max: 7.10512 velocity magnitude: 3.59437)
And I am able to capture the vortex. (URANS using conventional k-e and k-w models dont work!!!!)
Is it the correct solution that I have got or is the solution unphysical as the CFL condition states??
And my epsilon values blow up beyond bounds after some point. However I set things rite, by reducing the UnderRelaxation Factor.
Is the blow of epsilon related to CFL condition being violated?? Is my method of randomly changing the underrelaxation factor to achieve convergence rite??
Please help me out!!!!!
Regards,
Barath Ezhilan.
barath.ezhilan is offline   Reply With Quote
Old   November 2, 2009, 05:36
Bernard Esterhuyse
bernarde is on a distinguished road
Hi Barath
Have you had any success with your simulation? I'm looking at a similar type of simulation (vortex flow in a tube). I would like to share some ideas if you are still working on this.
Regards
Bernard
bernarde is offline   Reply With Quote
Old   September 24, 2010, 08:48
maysmech's Avatar
maysmech is on a distinguished road
hello,
i have same question. i am seeking Co limit for RAS and LES using pisoFoam.
maysmech is offline   Reply With Quote
cfl condition, courant number limit
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
