rUA inside/outside PISO loop
Old   July 28, 2009, 14:28
Default rUA inside/outside PISO loop
John Deas
johndeas is on a distinguished road
I have a question regarding the position of the computation of rUA in les codes. In do not understand if it is important to have it take place inside or outside the PISO loop, and to what extent this affect the solver.
In channeloodles:
volScalarField rUA = 1.0/UEqn.A();
for (int corr=0; corr<nCorr; corr++)
In oodles:
My hypothesis is that, since UEqn uses phi from last timestep to create its coefficients, rUA is never modified inside the PISO loop (the new phi computed here is never used to modify the UEqn), and can be calculated outside as well.
1. Is this correct ?
2. If yes, why isn't rUA calculated once and for all outside the PISO loop, in oodles too ?
johndeas is offline   Reply With Quote
Old   September 24, 2009, 13:55
Dr. Fabian Schlegel
fs82 is on a distinguished road
Did you now an answer up to now? I am also wondering why rUa is one time included in the PISO loop and one time not. I stored UEqn.A() in a tmp variable outside the PISO loop and compared UEqn.A() with my tmp variable every PISO loop step. There was no change. The difference was zero. So I think its equal to write it inside or outside of PISO loop :-D
kind regards,
Fabian
fs82 is offline   Reply With Quote
Old   October 1, 2009, 18:20
Ola Widlund
olwi is on a distinguished road
You might find this note useful: http://www.tfd.chalmers.se/~hani/kur...7/rhiechow.pdf
That site is well worth looking at in general -- there's a lot of useful slides and student papers on Op-nFOAM.
/Ola
olwi is offline   Reply With Quote
Old   October 2, 2009, 03:53
Dr. Fabian Schlegel
yes I know this "paper" but in my opinion it is more usefull to read the book of ferziger and peric "Computational Methods for Fluid Dynamics". They describe the PISO algorithm much more in detail and its fundamentals. But the main problem is to find the different equations in the source code. The paper is nice but I missed a little bit the link between theory and source code :-D
Fabian
Old   October 21, 2009, 08:28
John Deas
fs82: I just moved on other problems , still have no answers on that one...
Old   October 22, 2009, 08:13
Dr. Fabian Schlegel
As I mentioned above, there is no change in the UEqn.A() Operator during the PISO loop. I think is correct, because you only evaluate the correction terms in a PISO approach. So in my opinion its equal to write it inside or outside of the loop.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
PISO loop 21kalee OpenFOAM Running, Solving & CFD 2 January 15, 2008 06:31
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 15:34
Mistake in PISO loop for interFoam solver kumar2 OpenFOAM Running, Solving & CFD 3 June 30, 2006 19:26
