July 27, 2009, 04:57 |
icoLagrangianFoam parallelizatrion problem
Mihails Ščepanskis
Rep Power: 17 |
Dear all,
I work with icoLagrangianFoam solver on a cluster. It works good on one processor, but it doesn't work on 8 processors. At some time step it can't move particles. I don't receive any error, solver stil works but without any result. Do you know this problem? |
July 27, 2009, 21:02 |
edison
Rep Power: 17 |
I'm testing it with 4 processors and get the same problem. Hope some one can try to give and explanation.
Thanks so much. |
July 28, 2009, 08:30 |
#3 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- which OF-version are you working with - where did you get the icoLagranian-sources from (The one from the OF-extend-svn should be the more recent) - does this happen with the minimal parallel setup (==2 CPUs) too - is the problem reproducible with one of the two example-cases Bernhard |
July 28, 2009, 08:48 |
Mihails Ščepanskis
Rep Power: 17 |
Bernhard,
thank you very much for answer. I should say at first, I'm new openFOAM user. - I use openFoam-1.5 - I got icoLagrangianFoam from https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breeder_1.5/solvers/other/IcoLagrangianFoam/ - yes, this happens with 2 CPUs too - I worked with one of examples (it was cavityLagrange) |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
