MutiSpecies Reacting Flow
Old   July 26, 2009, 03:30
Default MutiSpecies Reacting Flow
Sanjib Das Sharma
sanjibdsharma is on a distinguished road
Hi All,
I have been trying to create a model for multi-species turbulent reacting flow (not Combustion). After going through the threads, I am finding it difficult to understand some of the key issues which I am listing below:
1) What *.H files are required ?
I have included the following:
i) multiComponentMixture.H
ii) UEqn.H, pEqn.H, hEqn.H,YEqn.H
iii)turbulenceModel.H, transportModel.H
iv) chemistry.H, reactingMixture.H,readChemistryProperties.H
2) I have modified the reactingFoam.C file to remove/add the required files to convert into a Multi-Component-Reacting file --- will this change work ?
3) Since I am using a incompressible turbulence model, what changes are required to convert the simpleFoam into a multispecies reacting flow model ? What header files are to be included ?
4) In the transportProperties and thermophysicalProperties input files, how do I include rho and Cp as a function of the species mass-fraction?
Pls let me know as soon as possible. It would be great if there are some examples or tutorials.
Thanks in advance.
Sanjib
sanjibdsharma is offline   Reply With Quote
Old   August 2, 2009, 09:14
Ville Tossavainen
villet is on a distinguished road
Hi Sanjib,
can you tell us more about your case?
- You have a certain number of species, a mixture of reacting gas/liquid?
- How do you define the reactions?
I was wondering why "reactingFoam" isn't suitable for you. Is it because of the chemistry library in OpenFOAM?
Ville
villet is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
reacting flow p kumar Main CFD Forum 0 December 31, 2002 04:16
turbulent reacting flow abdou chaabane Main CFD Forum 2 July 21, 1999 15:39
