initial velocity field with a pressure difference
Old   July 23, 2009, 05:20
Default initial velocity field with a pressure difference
Sven Degner
sven82 is on a distinguished road
hi,
Im not really sure about my initial fields, and i hope everyone help me with this problem.
first of all I create a simple geometries.
For the next step I will initial my p and U fields
The problem now my velocity field is define by a pressure difference .
The question is that the correct definition, for this problem?
/************************************** p *************/
outlet
type fixedValue;
value uniform -50000;
inlet
type zeroGradient;
/************************************** U *************/
outlet
type zeroGradient;
inlet
type zeroGradient;
sven82 is offline   Reply With Quote
Old   July 23, 2009, 05:59
Julien Schaguene
Schag is on a distinguished road
I think there is something missing here.
If you want your flow to be defined by a pressure difference, you have to put fixedValue to outlet AND inlet, otherwise your domain is going to have a uniform relative pressure equal to -50000, and in theory no velocity...
For further precision, we'll need explanations on geometry, solver used...
Schag is offline   Reply With Quote
Old   July 23, 2009, 06:05
kjetil is on a distinguished road
Also, this seems to be the boundary condition - not actually the initial field? The initial condition can be set in the internalField, located above you boundaryField. For example internalField uniform <your-number>; .
kjetil is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Parallel rasInterFoam openfoam_user OpenFOAM Running, Solving & CFD 4 November 1, 2008 05:14
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
