Problem in simulation
Old   July 21, 2009, 08:28
Default Problem in simulation
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi Foamers,
I am starting to feel desperate. I am simulating the flow of complex fluids in OpenFoam, where extra tensions are significant. In the momentum balance equations there is an extra divergence term of the extra tension. Right now, I am doing the simulations imposing in the fvSchemes upwind for the advection terms, but the divergence of extra tension is discretized using Gauss Linear Corrected.
I noticed that the behaviour is better, but, when the extra tension is large, ths simulation blows suddenly. It starts converging, and out of the blue the velocity and pressure values.
What I can do to avoid this? Some possibilities I am thinking of are:
- instead of starting with a flow field with zero velocity use a flow field that has converged and then change the parameters.
- use other linear solvers or reduce the total errors.
- try other relaxation factors.
Has anybody other ideas.
Regards,
Titio
titio is offline   Reply With Quote
problem in tornado simulation with FLUENT, please help Kestas FLUENT 10 April 25, 2012 07:20
Problem of heat balance in Coal Boiler simulation DG FLUENT 9 December 25, 2008 21:57
problem of river flow simulation Liu Main CFD Forum 0 May 27, 2004 23:01
2D simulation as boundary condition for 3D problem Jan De smet FLUENT 1 October 11, 2002 03:02
simulation of incineration problem xinxin Main CFD Forum 1 November 27, 1999 17:34
