Problem with leastSquares scheme when using dynamicRefineFvMesh
Old   July 9, 2009, 07:36
Default Problem with leastSquares scheme when using dynamicRefineFvMesh
Christian Kunkelmann
christian_kunkelmann is on a distinguished road
Dear all,
I would like to apply leastSquares schemes for grad(gamma) when I use the VOF solvers of OpenFOAM because I realized that they do a pretty good job on the mesh that I use. However, when I use the adaptive mesh refinement feature (dynamicRefineFvMesh) with interDyMFoam I do not get good results. The simulation runs well until the mesh is updated for the first time (after 10 timesteps in my case).
When I let the solver write the gradient field and visualize it in paraview I can see that the arrows point in the right direction in the beginning of the simulation. After the refinement, the arrows point randomly in almost any possible direction which causes the interface to become unstable.
Is it possible that the leastSquares schemes need some kind of reinitialization when the mesh has changed. If yes, how could this be implemented. I have alread tried calling mesh.fvSchemes::read() after mesh.update() but the results did not change.
Thanks in advance for your support.
Regards,
Christian
christian_kunkelmann is offline   Reply With Quote
Old   July 9, 2009, 12:34
Default Problem with leastSquares scheme when using dymanicRefineFvMesh
I just made an interesting observation:
When I stop the simulation after the first refinement and restart it from that time (i. e. with the refined mesh) the gradient are calculated correctly...
... which again lets me think that the leastSquares scheme apparantly needs some kind of reinitialization when the mesh has been refined.
I am looking forward to your comments/suggestions!
Thanks again!
Christian
Old   July 10, 2009, 12:19
Hrvoje Jasak
Fixed in 1.5-dev a long time ago.
Hrv
Hrvoje Jasak
dynamicrefinefvmesh, gradient scheme, interdymfoam, interfoam, leastsquares
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
OpenFOAM15dev interDyMFoam problem using dynamicRefineFvMesh eberberovic OpenFOAM Bugs 6 January 14, 2010 06:18
Question on Sediment Mass Conservation Scheme Wen Long Main CFD Forum 0 July 6, 2004 16:45
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
Mac Cormack scheme and use of PML boundary conditi vineet kshirsagar Main CFD Forum 1 January 13, 2002 02:46
