boundary layer grid resolution for Spalart-Allmaras model
Old   June 21, 2009, 17:28
Default boundary layer grid resolution for Spalart-Allmaras model
wei wu
wei_wu is on a distinguished road
hello everyone!
I have some questions about the boundary layer cells thickness for the S-A model.
1.. I understand that in order to get better results by using S-A model without wall function you need to make yPlus in the range of order 1. I wonder how the results will be if I use a much finer bundary layer grids , like yPlus in the order of 0.001? Is it just a waste of time without any improvement of the results or it will yield a worse one.
2.. how many cells in the boundary layer in the direction normal to the wall is a good choice, any guidelines?
3..if I use the boundary layer cells which have high aspect ratio like over 100, will that affect the accuracy a lot?
Thank you all for reading.
Wei
wei_wu is offline   Reply With Quote
Old   June 23, 2009, 17:53
wei wu
anyone has any ideas? thanks
3D Boundary Layer Mario FLUENT 0 February 17, 2009 04:40
Reynolds transport, turbulence model, etc Beginner Main CFD Forum 1 January 7, 2009 06:36
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Errors in Gambit for boundary layer mesh Mike Spears FLUENT 0 June 23, 2005 12:34
k-omega model and boundary layer K S Chang Main CFD Forum 1 December 15, 2003 08:28
