Error with 'vanAlbada' scheme
Old   June 18, 2009, 10:31
Default Error with 'vanAlbada' scheme
Julian Krick
Julian K. is on a distinguished road
Hallo,
I'm using the sonicFoam solver for my flow problem. For the discretization of the convective terms I'd like to use the the 'vanAlbada' scheme. Here is the excerpt from my /system/fvSchemes file:
divSchemes
    default         none;
    div(phi,U)      Gauss vanAlbada;
    div(phid,p)     Gauss vanAlbada;
    div(phi,e)      Gauss vanAlbada;
When I try to run the computation I get the following output:
Create time
Create mesh for time = 0
Reading thermodynamicProperties
Reading transportProperties
Reading field p
Reading field T
Calculating field e from T
Reading field U
Starting time loop
Time = 1e-08
Lookup interpolationScheme for interpolate(rho)
Courant Number mean: 0 max: 0
Lookup ddtScheme for ddt(rho)
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
Lookup laplacianScheme for laplacian(mu,U)
Lookup fluxRequired for U
Lookup gradScheme for snGradCorr(U)
Lookup divScheme for div(phi,U)
Lookup gradScheme for grad(magSqr(U))
Lookup ddtScheme for ddt(rho,U)
Lookup gradScheme for grad(p)
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 3.76603e-12, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 8.97676e-10, No Iterations 1
Lookup gradScheme for grad(U)
Lookup laplacianScheme for laplacian(mu,e)
Lookup fluxRequired for e
Lookup gradScheme for snGradCorr(e)
Lookup divScheme for div(phi,e)
Lookup gradScheme for grad(e)
#0  Foam::error::printStack(Foam::Ostream&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib64/libc.so.6"
#3  Foam::LimitedScheme<double, Foam::vanAlbadaLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#4  Foam::limitedSurfaceInterpolationScheme<double>::weights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#5  Foam::fv::gaussConvectionScheme<double>::fvmDiv(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#6  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam"
#7  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam"
#8  main in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam"
#9  __libc_start_main in "/lib64/libc.so.6"
#10  Foam::regIOobject::readIfModified() in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam"
Gleitkomma-Ausnahme
Maybe the error occured due to an incorrect definition of the scheme - I couldn't find any example and, since I'm quiet unfamiliar with OpenFOAM, I couldn't read it from the source code.
Does anyone have a suggestion?
Thanks for reading my thread,
bye
Julian
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 03:41
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 12:21
