dieselFoam Error
Old   June 16, 2009, 12:50
Default dieselFoam Error
Rachel Vogl
Rachel is on a distinguished road
Hello everyone,
I am trying to solve a problem with following reaction.
Due to help from 2 other threads I have reached a point where the solver starts iterations, however it exits in the first time step.
Any clues why this could be heppening?
Thanks,
Rachel
Create time
Create mesh for time = 0
Reading thermophysicalProperties
Selecting thermodynamics package hMixtureThermo<reactingMixture>
Selecting chemistryReader chemkinReader
Reading field U
Creating turbulence model.
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
alphah 1;
alphak 1;
alphaEps 0.76923;
muLimiter on;
Lsgs 0.0002;
Creating field DpDt
Constructing chemical mechanism
Selecting ODE solver SIBS
chemistryModel::chemistryModel: Number of species = 4 and reactions = 1
Reading environmentalProperties
Reading combustion properties
Constructing Spray
--> FOAM Warning :
From function Cloud<ParticleType>::initCloud(const bool checkClass)
in file /home/rachel/OpenFOAM/OpenFOAM-1.5.x/src/lagrangian/basic/lnInclude/CloudIO.C at line 51
Cannot read particle positions file
"/scratch/rachel/coalgas_syn6a1_3spray/0/lagrangian/defaultCloud"
assuming the initial cloud contains 0 particles.
--> FOAM Warning :
From function entry::getKeyword(word& keyword, Istream& is)
in file db/dictionary/entry/entryIO.C at line 72
Reading /scratch/rachel/coalgas_syn6a1_3spray/constant/sprayProperties
found on line 183 the punctuation token '{'
expected either } or EOF
Selecting injectorType unitInjector
Selecting atomizationModel off
Selecting dragModel standardDragModel
Selecting evaporationModel standardEvaporationModel
Selecting heatTransferModel RanzMarshall
Selecting wallModel remove
Selecting breakupModel ReitzKHRT
Selecting collisionModel off
Selecting dispersionModel off
Selecting injectorModel hollowConeInjector
Selecting pdfType RosinRammler
Average Velocity for injector 0: 195.235 m/s, injection pressure = 247.667 bar
Average Velocity for injector 1: 195.235 m/s, injection pressure = 247.667 bar
Average Velocity for injector 2: 195.235 m/s, injection pressure = 247.667 bar
Constructing three dimensional spray injection.
Courant Number mean: 0 max: 0.000980191
Starting time loop
Courant Number mean: 0 max: 0.0980191
deltaT = 0.00025
Time = 0.00025
Evolving Spray
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 7.0502e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.737e-10, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.01832e-09, No Iterations 2
DILUPBiCG: Solving for CO, Initial residual = 1, Final residual = 6.30454e-07, No Iterations 1
DILUPBiCG: Solving for CO2, Initial residual = 1, Final residual = 6.30453e-07, No Iterations 1
DILUPBiCG: Solving for H2O, Initial residual = 1, Final residual = 6.30453e-07, No Iterations 1
DILUPBiCG: Solving for H2, Initial residual = 1, Final residual = 6.30453e-07, No Iterations 1
#0 Foam::error::printStack(Foam::Ostream&) in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator=(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/dieselFoam"
#4 main in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/dieselFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 __gxx_personality_v0 in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/dieselFoam"
Segmentation fault
Rachel is offline   Reply With Quote
Old   June 16, 2009, 15:45
Mattijs Janssens
mattijs is on a distinguished road
According to your log you have a syntax error in your sprayProperties. Might be a problem.
mattijs is offline   Reply With Quote
Old   June 17, 2009, 06:37
Rachel Vogl
Thanks Mattijs,
I was trying to use 3 sprays in the system. Hence I modified sprayProperties.
Now i have switched back to single spray, to test the chemistry. However there is something else thats going wrong and segmentation fault is not that helpful.
Here is the new log
| \\ / O peration | Version: 1.5.x |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : /home/rachel/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/dieselFoam
Date : Jun 17 2009
Time : 10:21:29
Host : euler
PID : 23405
Case : /scratch/rachel/gas6a1
nProcs : 1
Create time
Reading field U
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
alphah 1;
alphak 1;
alphaEps 0.76923;
muLimiter on;
Lsgs 0.0002;
Creating field DpDt
Constructing Spray
--> FOAM Warning :
"/scratch/rachel/gas6a1/0/lagrangian/defaultCloud"
Starting time loop
deltaT = 0.00025
Time = 0.00025
Evolving Spray
Solving chemistry
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>:perator=(Foam::tmp<Foam::Geometri cField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/rachel/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/dieselFoam"
Segmentation fault
Old   June 17, 2009, 07:59
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
my guess is that your timestep is too large.
200 m/s injection velocity and 0.25 ms integration step.
that means your parcels will travel approx 5 cm.
The momenum transfer to the gas will be too high.
niklas is offline   Reply With Quote
Old   June 24, 2009, 11:22
Rachel Vogl
Thanks everybody,
It was a problem of setting the right initial/boundary conditions. Since the domain had inlet & outlet, I used BC similar to reactingFoam (from wiki) and then used dieselFoam solver. Now awaiting the results...
Thanks,
Rachel
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
