June 16, 2009, 07:53 |
#21 | |
Niklas Nordin
Rep Power: 29 |
If you check them you will see that in the N2-file you have a line that reads like this - internalField uniform 0.766; and in the O2-file you have a line that reads like this - internalField uniform 0.233; These two species form 'air'. I will leave it up to you to figure out how to modify it so you only have N2. |
June 16, 2009, 17:20 |
initial condition
#22 |
amin
Rep Power: 17 |
Hi
I know that these (N2 & O2 files in 0 directory) are initial condition for chamber gas.I am not sure about it when I change them to for example N2=1.0 and O2=0.0,is it like that chamber gas is only N2 in all of time steps? But in thermophysicalProperties file I introduce chemkin file that include species like O2 N2 Co2 H2o,doesn't dieselfoam use these species as chamber gas for next time steps? which part of code call for gas properties or where can I see gas properties in Src? I change N2 to 1.0 and O2 to 0.0 but my result did n't effect any more(SMD & liquidpenetration).also I changed N2 to 1.0 and O2 to 1.0 but dieselfoam did not generate an error,How is it? what is the role of inertSpecie in thermophysicalProperties file ? Please guid me to select N2 just as a chamber gas. thanks regard |
June 17, 2009, 04:04 |
#23 | ||||
Niklas Nordin
Rep Power: 29 |
You have to specify boundary conditions and initial conditions for every specie that you define in chem.inp, but to make life easier there is a file called Ydefault. Lets say you have NO2, NO, CO, OH defined in the chem.inp. Normally you would set the initial massfraction to zero for these, but if you have alot of species its quite exhausting just setting everything to zero, thats where the Ydefault file comes in. So if you havent got a file for NO2, NO, CO or OH the solver will look for a file called Ydefault and use the intial conditions and boundary conditions from that file. Take a look in the file src/thermophysicalModels/combustion/mixtureThermos/mixtures/combustionMixture/combustionMixture.C if you want to see how it is done. Quote:
all the species will have the laminar viscosity-coefficients hardcoded for the sutherland expression to 1.67212e-6 and 170.672 this is done in src/thermophysicalModels/combustion/chemistryReaders/chemkinReader/chemkinLexer.L You can look here for more info on format http://openfoamwiki.net/index.php/Contrib_dieselFoam Quote:
Usually you use N2 in experiments to avoid combustion, but in the CFD world you can just set the chemistry to off in chemistryProperties to turn off all the reactions. When the massfractions are read everything will be normalized to 1. Just run a few timesteps and check the values and you will see that they will have changed to 0.5. Quote:
the inertSpecie will instead be calculated as 1- sum(Yi) check the file applications/solvers/combustion/dieselEngineFoam/YEqn.H |
June 18, 2009, 02:55 |
diesel Fuel
#24 |
amin
Rep Power: 17 |
Hi
thank you very much for your complete answers dear Dr Nordin. I found that fuel properties that I want to use are close to diesel fuel.does openfoam has properties of these fuel? I check in SRC and found C12H26,is this fuel used as diesel fuel in common? I now that C12H26 is one of the component of diesel fuel. is it correct to use it as diesel fuel? I used C12H26 in thermophysical properties file and chemkin file as second fuel But when I ran diesel fuel I face an error, I check therm.dat file in chemkin directory of case but I didn't find C12H26 coefficient in this file,I am sure that this error is related to this file. then how can i find these coefficient? Do you have these coefficient.I will be thankful if you send them for me. Thanks regard |
June 22, 2009, 07:07 |
#25 |
Niklas Nordin
Rep Power: 29 |
June 22, 2009, 22:25 |
nasa polynomial
#26 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin;
I am thankful for your kindly help.I am so glad that have a friend like you. I also found a pdf like this: http://www.docstoc.com/docs/4201307/...ondensed-Phase Thanks Regard |
June 22, 2009, 22:29 |
Kiva Or openFoam
#27 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin;
I know that you work with both KIva and openFoam code,I have a question: Which of them are really suitable for simulating spray simulation? |
June 23, 2009, 03:00 |
#28 |
Niklas Nordin
Rep Power: 29 |
June 23, 2009, 05:31 |
kiva or openfoam
#29 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin;
first by following my last question I am planning to alter/add something on my own,which one I would pick? second I copy new therm.dat file that you putted for me,but I face this error : | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : dieselFoam Date : Jun 23 2009 Time : 22:35:57 Host : spray PID : 8865 Case : /home/openfoam1.5/OpenFOAM/openfoam1.5-1.5/run/tutorials/dieselFoam/aachenBomb nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysicalProperties Selecting thermodynamics package hMixtureThermo<reactingMixture> Selecting chemistryReader chemkinReader C12H26 not found in table. Valid entries are 820 ( CH3CHCL CL2SISICL CH3CHCH SIF2N A2C2H>2 CH3OCL CH2CCLOH . . . . . CCL2CCLO H2SINH3 KO2<S> A1C2H3* A1C2H>2 CLCH2OH H2SISIH2 CCL3CCLO H3SICH2 H3SICH3 ) in which table I would define C12H26? thanks regard |
June 23, 2009, 05:55 |
#30 |
Niklas Nordin
Rep Power: 29 |
Its clearly telling you that it cannot find C12H26 in therm.dat
thats because in Burcat's file the name is N-DODECANE Code:
C12H26 T 5/99C 12H 26 0 0G 200.000 6000.000 1000.000 1 3.70187925E+01 5.54721488E-02-1.92079548E-05 3.08175574E-09-1.84800617E-13 2 -5.26984458E+04-1.61453501E+02 2.13264480E+01-3.86394002E-02 3.99476113E-04 3 -5.06681097E-07 2.00697878E-10-4.22475053E+04-4.85848300E+01-3.49836226E+04 4 |
June 23, 2009, 11:35 |
saving liquid spray penetration
#31 | |
José M. Pastor
Rep Power: 17 |
I'm a begginer into OpenFoam and C++. Maybe this is an obvious question. In order to write liquid penetration, did you include those lines into dieselFoam.c or did you create a *.h such as spraySummary.h? Is required any additional coding in order to use 'ofstream' into dieselfoam.c ,e.g. #include <iostream> #include <fstream> using namespace std;? Thanks. Quote:
June 23, 2009, 12:23 |
liquid peneteration
#32 |
amin
Rep Power: 17 |
Hello Dear Pastor;
of course you can add these line in both place in spraysummary.h or dieslFoam.c,because dieselFoam call this *.H file in main program but I directly wrote these lines to dieselfoam.c after line :Incloude" spraysummary.h" or you can copy paste the lines inside spraysummary.h to dieselfoam.c and then write this code to dieselfoam.c. second when you usestd::ios::app, it is enough, you don't need to write using namespace std; regard |
June 23, 2009, 12:27 |
C12h26
#33 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin
No,I changed Therm.dat(N-DODECANE ->C12H26) before I ran dieselfoam,but it generated this error. what is the problem? regard |
June 23, 2009, 12:28 |
C12h26
#34 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin
June 23, 2009, 12:41 |
#35 | |
José M. Pastor
Rep Power: 17 |
Hi John,
Thanks for your answer. I also add those lines after 'include "spraySummary.H" ' but does not work for me. I get the following compilation error dieselFoam.C: In function âint main(int, char**)â: dieselFoam.C:117: error: expected initializer before âstdâ dieselFoam.C:119: error: âpenetâ no se declaró en este ámbito make: *** [Make/linux64GccDPOpt/dieselFoam.o] Error 1 I'll keep trying... Quote:
June 24, 2009, 03:14 |
#36 | |
Niklas Nordin
Rep Power: 29 |
Check thermophysicalProperties and see which file you are using. CHEMKINThermoFile "~OpenFOAM/thermoData/therm.dat"; |
June 25, 2009, 05:29 |
validating exprimental case
#37 |
amin
Rep Power: 17 |
Hi Dear Dr Nordin;
Thanks. yes,I make a mistake. Now I am trying to validate a non-evaporating spray of C7H16 experiment with these characteristic: max.injection pressure= 60 Mpa injection duration=2.36 ms mass of fuel= 9.84 mg Diameter of the nozzle=0.02 cm ambient temperature = 293 k ambient pressure =17 bar But my result has a large difference with experiment. I attached a zip file including my diselfoam case setup, my tip penetration results and experiment results. it seems that spray can not penetrate in chamber,I changed ambient pressure of 17 bar(17e+5) to (1.7e+5) and strangely my result of tip penetration were close to experiment. I don't know what is my problem. it seems that ambient pressure should be 1.7e+5. please help me,I am confused. Thanks Regard |
June 25, 2009, 10:44 |
#38 |
Niklas Nordin
Rep Power: 29 |
you cant run a 2D simulation like that.
June 25, 2009, 10:53 |
correct mesh
#39 |
amin
Rep Power: 17 |
hi
what is my mistake? what is its correction? how can i describe an axi-symmetric mesh for diesel foam? thanks regard Last edited by az1362f; June 25, 2009 at 11:16. |
June 26, 2009, 05:40 |
3D mesh
#40 |
amin
Rep Power: 17 |
hi Dear Niklas
what is my mistake? what is its correction? how can i describe an axi-symmetric mesh for diesel foam? I ran a 3D simulation of dieselfoam with last characteristic of n-heptane experiment and add its result to a new plot and attached it. there are two strange things: 1- I saw some fluctuations in liquid penetration curve in 3D cases. 2- likewise liquid penetration is far from experimental result. what is the reason of these? I set the initial drop diameter to nozzle diameter according to injector model.is it correct? I am confused. Please help me. thanks regard Last edited by az1362f; June 27, 2009 at 12:33. |
