High density flow - twoPhaseEulerFoam solver
Old   May 29, 2009, 05:49
Default High density flow - twoPhaseEulerFoam solver
Raghavendra
raagh77 is on a distinguished road
Send a message via Yahoo to raagh77 Send a message via Skype™ to raagh77
Hello all,
As a part of my master thesis
I am trying to simulate Steel-Argon flows (steel continuous phase and argon discrete phase) with free surface and the simulation is not stable.
I have limited the courant number to 0.85, after few iterations very small time steps will be used (of the order 1e-06) and simulation crashes with high courant number.
Before this I tried water (continous)-air(discrete) simulation with the same grid, inital conditons and boundary conditions.
But now whe n I change the density of the continous phase from 1000 to 7000 (Steel density) simulation crashes.
Do I need to change the coefficients of Cvm, Cl and Ct in constant/transportProperties ?
awaiting for your suggestions
Regards
Raghavendra
raagh77 is offline   Reply With Quote
Nonphysical flow field while using coodles solver ankgupta8um OpenFOAM Running, Solving & CFD 5 January 26, 2008 17:54
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 03:41
Solver fails with compressible flow Eric CFX 4 February 4, 2006 09:28
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
CFD method for High Re flow Toshiyuki Arima Main CFD Forum 3 May 29, 2001 12:18
