coupling OpenFOAM with other programs
Old   May 26, 2009, 12:30
Default coupling OpenFOAM with other programs
Martin Tek
Martin123 is on a distinguished road
I am Martin and new to OpenFOAM. I want to solve the Laplace-Equation
grad(k(x)*grad u(x))=0 with OpenFOAM and interconnect k(x) with data coming from outside.
Is there any possibility to read in and write out dynamically on run-time the k(x) values into a VolScalarField (I'd guess) ? And to access maybe the nearest node for a given coordinate? Or at least to iterate over all nodes, get the coordinates and get/set k(x)?
Any help is appreciated.
Martin
Martin123 is offline   Reply With Quote
Old   May 28, 2009, 22:02
Henrik Rusche
henrik is on a distinguished road
Dear Martin,
the bottom line is that you can do anything because you have the source code. If you have the source code for the other code, then merging the two codes into a single executable is easier & faster than file IO while avoiding syncronisation problems. However, this is major surgery and you need to know what you are doing. Concerning your questions:
@reading
I would simply create a (temporary) field from an IOobject. Look at any createField.H and place the code inside of the time loop.
However, field.read() should work, too.
@writing:
field.write();
@finding cell numbers:
vector pos;
label cellI = mesh.findCell(pos);
Info << field[cellI] << endl;
@iterate cell centers:
forAll(mesh.C(), cellI)
    vector pos;
    if ( mag(mesh.C()[cellI] - pos) < SMALL)
        field[cellI] = newValue;
Hope this helps.
Henrik
henrik is offline   Reply With Quote
Old   June 2, 2009, 06:26
Martin Tek
Dear Henrik,
thank you very much for you help, this is exactly what I was looking for.
I followed your suggestion and created and temporary field during the runtime-loop; unfortunately, OF claims that it cannot read my temporary field
volScalarField epsilon
IOobject
"epsilon",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::NO_WRITE
mesh
cannot open file
file: /home/dw9203/projects/ofoprj/cavity/0.005/epsilon at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
But it should however not read from disk, I want to specify the field values during run-time. Could you enlighten this?
Old   June 3, 2009, 19:13
Martin Tek
Thanks, now it works setting values on run-time. A different constructor for volscalarfield made it and I can set now values during run-time. Great!
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
