Parallel "icoDyMFoam" (min(const UList<Type>&) / FieldFunctions.C / empty field) |
May 8, 2009, 14:26 |
#21 | |
Rep Power: 17 |
@Olivier: Thanks again, you were a great help to me so far. |
May 11, 2009, 10:03 |
Short update
#22 |
Rep Power: 17 |
I have disovered that it works fine when using only one CPU.
Currently I am trying to find out whether it has to do with movingCells. The statement "Number of moving cells in the moving region" shows the wrong number of cells when using multiple CPUs. |
November 25, 2009, 12:31 |
#23 |
Andreas Dietz
Rep Power: 17 |
If your mesh turns in the wrong direction just give your rpm value in constant/dynamicMeshDict a negative signum.
Last edited by lord_kossity; November 25, 2009 at 13:01. Reason: Attachement of images |
August 4, 2010, 05:29 |
Did you resolved your problem?
#24 | |
Aldo Iannetti
Rep Power: 16 |
Hi, IDid you resolve your problem? I think I have the same problem with turbDyMFoam, I have the stator volume rotating together with the rotor volume. Thanks Aldo |
icodymfoam, mixerggifvmesh, parallel |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Parallel FOAM FATAL IO ERROR | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | July 28, 2006 13:48 |
