April 23, 2009, 11:50 |
potentialFoam around a sphere ; mesh by Gmsh
Eliam H
Rep Power: 17 |
Hi all
I'm new in OpenFOAM. I use it for an automotive application but I want to begin with easier cases. I'm trying to study the flow around a sphere with potentialFoam (as a begin). I made my sphere with blender, exported it in STL format. I make the fluid domain and the mesh with Gmsh. I import the .msh file with gmsh2ToFoam. checkMesh give me OK in spite of non-orthogonal faces. potentialFoam seems to work well. But when I posttreat the results I see that the velocity magnitude reach more than 7000 m/s (I had 40 m/s in inlet, with 1 m/s it reaches more than 1000 m/s). I run the potentialFoam/cylinder example case whithout any problem. I think that the problem comes from the mesh but I don't know any more where to look for. My case folder is online at : http://eherichon.perso.ec-marseille....le/gmsh.tar.gz (4.1 M) Any help would be welcome . Thank you Eliam |
April 24, 2009, 06:33 |
Eliam H
Rep Power: 17 |
Hi all
I just tried my case with a mesh generated by snappyHexMesh from the same STL sphere. I have now "good" results. So the problem come from the mesh. Maybe the topic should be moved to the mesh part. Sorry. Has somebody idea to generate a "good" mesh with Gmesh ? (or other OpenSource Mesher). Thanks. Eliam |
April 24, 2009, 10:06 |
Eliam H
Rep Power: 17 |
Checking two options in Gmesh I get a good mesh :
Tools / Options / Mesh / Advanced - Optimize quality of tetraedra - Optimize quality of tetraedra with NetGen |
July 27, 2009, 21:31 |
J. Cai
Rep Power: 17 |
Hi, Eliam, I meet the same problem just like yours. My mesh is converted from Fluent. checkMesh also give me OK, and potentialFoam seems to work well.
However some velocity magnitudes reach very large (over 1e+06). And my case is very complicated, I am not sure it can be generated by snappyHexMesh. Do you have any comments? Thank you. Chiven |
July 28, 2009, 03:36 |
Eliam H
Rep Power: 17 |
Hi Chiven.
"Ok" by checkMesh seems to be not enough. Have you non-orthogonal faces ? |
July 28, 2009, 04:00 |
J. Cai
Rep Power: 17 |
Hi, Eliam, thanks for your friendly reply. The follows are the prompt when run checkMesh.
Best regards, Chiven Create polyMesh for time = constant Time = constant Mesh stats points: 289762 faces: 3121097 internal faces: 2980747 cells: 1525461 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 1525461 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology wall 134626 67762 ok (non-closed singly connected) pump-in 334 200 ok (non-closed singly connected) ec-in 54 37 ok (non-closed singly connected) dc-left 1218 703 ok (non-closed singly connected) dc-bot 1450 849 ok (non-closed singly connected) dc-right 1220 704 ok (non-closed singly connected) dc-top 1448 848 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.32 -0.1035 -0.5) (2.90989 2.38459 0.2) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (4.85517e-17 2.16681e-16 1.84246e-17) OK. Max cell openness = 2.71454e-16 OK. Max aspect ratio = 8.39433 OK. Minumum face area = 7.73192e-06. Maximum face area = 0.000113308. Face area magnitudes OK. Min volume = 1.21101e-08. Max volume = 3.44939e-07. Total volume = 0.151526. Cell volumes OK. Mesh non-orthogonality Max: 66.6416 average: 19.7369 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.956777 OK. Mesh OK. |
July 28, 2009, 07:02 |
Eliam H
Rep Power: 17 |
Your mesh seems good. Have you post-processed your case to see the zone where the velocity is weirb ?
I don't use OpenFOAM for several months so I don't remember very good all the tricks I discovered. But reading your report again I wonder if your max skewness isn't a little high. (try to be under 0.85). Good luck ! |
July 28, 2009, 07:19 |
J. Cai
Rep Power: 17 |
Hi, dear Eliam, thank you very much for you precious time and patience. I do have seen the velocity distribution from paraFoam. The form of my case is not so regular. I am wondering whether OpenFoam can deal with so much complicated case.
Thank you again. best regards, Chiven |
July 28, 2009, 08:40 |
#9 |
Eliam H
Rep Power: 17 |
Hi Chiven
I'm not a specialist but I think that OpenFoam can compute complicated cases. (see the examples on the website) but you need a very good mesh. Have you compared the areas where you have high value of velocity and areas where you have high skewness ? |
July 28, 2009, 10:41 |
#10 |
J. Cai
Rep Power: 17 |
Hi, Eliam, I have checked the areas with large velocity, and written a report, and sent to my boss. I shall discuss with him tomorrow. It is time of 10:41 PM in Japan. However, about the skewness, I can not check it, my fluent mesh is from my boss. And I shall also discuss this point with him. When I solve this problem, I shall also tell you the answer.
Good news, the release 1.6 is published! There are many new funcitons. By the way, what is the experted engineering case using OpenFoam? Many people have also asked me what are the most successful engineering application examples by OpenFoam. But my computer is not able to open the Examples_of_Application webpage, maybe I can do it in my dormitory. I found many people only used OpenFoam to do some simple cases, and stopped. Thank you very much. Best regards, Chiven |
January 4, 2011, 10:57 |
#11 | |
Tao Zhu
Rep Power: 16 |
Hi Eliam, I have the same problem. I'm using Tetrahedron meshs, and some velocity magnitudes are 10000 after potentialFoam. My inlet velocity is just 69. Do you think it's probably the problem of mesh? Number of non-orthogonal faces: 109669 Thank you very much. |
January 5, 2011, 07:39 |
#12 |
Eliam H
Rep Power: 17 |
Try to have no more non-orthogonale faces ;-)
January 26, 2011, 04:02 |
#13 |
Matej Andrejasic
Hello Eliam
Can you please share with me your initial and boundary conditions you used for potential flow around the sphere or something else. It seem's I have some problems at boundary. Thank you in advance. Matej |
Converting mesh from gmsh | newbee | OpenFOAM Pre-Processing | 21 | January 22, 2010 07:51 |
hexa mesh around a sphere within a cylinder:fluent | HK | Main CFD Forum | 1 | March 20, 2008 11:54 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 13:16 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
Mesh distortion close to cylind wall-GAMBIT 2.2.30 | Mirek | FLUENT | 1 | April 15, 2006 18:22 |
