Difference between oodles and "oodLagrangianFoam
Old   April 21, 2009, 09:10
Default Difference between oodles and "oodLagrangianFoam
xinguang cui
flying is on a distinguished road
Dear all:
I have made a solver of oodLagrangianFoam as icoFoam.
Now everything is ok except there is some difference between the result of "oodles" and "oodLagrangianFoam" when I only compute the flowfield. The difference is as the below lines:
oodLagrangianFoam
Starting time loop
Reading/calculating field UMean
Reading/calculating field pMean
Reading/calculating field UPrime2Mean
Reading/calculating field pPrime2Mean
Time = 1e-06
Courant Number mean: 0 max: 0.000871632
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.81505e-09, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.25195e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.12197e-08, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0453494, No Iterations 166
time step continuity errors : sum local = 2.53027e-07, global = -7.12624e-10, cumulative = -7.12624e-10
DICPCG: Solving for p, Initial residual = 0.0592759, Final residual = 9.81774e-07, No Iterations 182
time step continuity errors : sum local = 1.52743e-09, global = -2.03866e-12, cumulative = -7.14663e-10
ExecutionTime = 5.06 s ClockTime = 5 s
Calculating averages
Time = 2e-06
Courant Number mean: 0.000147711 max: 0.00344423
DILUPBiCG: Solving for Ux, Initial residual = 0.347412, Final residual = 1.50109e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.407471, Final residual = 3.01995e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.33329, Final residual = 4.12535e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0651253, Final residual = 0.00246889, No Iterations 162
time step continuity errors : sum local = 2.76872e-06, global = 2.88385e-08, cumulative = 2.81238e-08
oodles:
Time = 1e-06
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.81893e-09, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.14863e-08, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.09542e-08, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.045263, No Iterations 166
time step continuity errors : sum local = 2.52412e-07, global = -7.21685e-10, cumulative = -7.21685e-10
DICPCG: Solving for p, Initial residual = 0.0592747, Final residual = 9.81467e-07, No Iterations 182
time step continuity errors : sum local = 1.52615e-09, global = -2.03287e-12, cumulative = -7.23718e-10
ExecutionTime = 5.16 s ClockTime = 6 s
Time = 2e-06
Courant Number mean: 0.000147626 max: 0.00344243
DILUPBiCG: Solving for Ux, Initial residual = 0.347412, Final residual = 1.49969e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.407459, Final residual = 3.01704e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.33329, Final residual = 4.12142e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0651229, Final residual = 0.0024665, No Iterations 162
time step continuity errors : sum local = 2.76459e-06, global = 2.8777e-08, cumulative = 2.80532e-08
DICPCG: Solving for p, Initial residual = 0.137205, Final residual = 8.74102e-07, No Iterations 184
time step continuity errors : sum local = 5.32549e-10, global = 1.23002e-12, cumulative = 2.80545e-08
ExecutionTime = 8.61 s ClockTime = 9 s
Ps: In fact I have tried to make everything is the same, but I don't know how the difference comes out.
Do you have some idea about it?
Thanks!
Xinguang Cui
flying is offline   Reply With Quote
Old   April 22, 2009, 13:32
matej forman
matejfor is on a distinguished road
Maybe I'm completely blind, but I could not see any difference. I mean there are some minor number difference, but ...
what are you BC? any turbulence forcing, or is there deterministic inlet, which gives always the same numbers to crunch? do you run the code parallel?
good luck
matej
matejfor is offline   Reply With Quote
Old   April 23, 2009, 14:55
xinguang cui
Thanks for your reply!
You are right, but it should be equal each other.In fact, BC is the same. The inlet condition is also sameI didn't run it in the parallel way.
the effect of upwind difference hades Main CFD Forum 8 March 15, 2009 00:43
Problem in testing oodles yejungong OpenFOAM Running, Solving & CFD 0 July 14, 2008 13:06
Specified Blend factor =1 Vs Central Difference Kushagra CFX 4 May 2, 2008 14:14
Difference between scaled residuals and... Dieter FLUENT 0 April 28, 2006 18:52
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
