June 14, 2012, 11:20 |
twoPhaseEulerFoam with LES - a quick (and dirty) shot
#41 |
Gerhard Holzinger
Rep Power: 28 |
I gave it a try to hack a large eddy turbulence model into twoPhaseEulerFoam.
My approach is based on the assumption, that with LES only nuEffa and nuEffb are directly influenced. So I changed the definition of them. Also the large eddy model is calculated for the mixture like it is done in multiPhaseEulerFoam. I added this code to createFields.H Code:
// new for LES singlePhaseTransportModel fluid(U, phi); autoPtr<incompressible::LESModel> sgsModel ( incompressible::LESModel::New(U, phi, fluid) ); Info<< "Calculating field nuEffa\n" << endl; volScalarField nuEffa ( IOobject ( "nuEffa", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), sgsModel->nut() + nua //sqr(Ct)*nutb + nua ); Info<< "Calculating field nuEffb\n" << endl; volScalarField nuEffb ( IOobject ( "nuEffb", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), sgsModel->nut() + nub //nutb + nub ); Code:
#include "singlePhaseTransportModel.H" #include "LESModel.H" Code:
//nuEffa = sqr(Ct)*nutb + nua; nuEffa = sgsModel->nut() + nua; /*volTensorField Rca ( "Rca", ((2.0/3.0)*I)*(sqr(Ct)*k + nuEffa*tr(gradUaT)) - nuEffa*gradUaT );*/ volTensorField Rca ( "Rca", ((2.0/3.0)*I)*(nuEffa*tr(gradUaT)) - nuEffa*gradUaT ); I attached the source files, from which I removed stuff related to kinetic theory (which I do not need). For reasons of file size limitation the folders Make, interfacialModels and phaseModel are not included in the archive. There is also a modified case based on the pitzDaily tutorial of pisoFoam included. The initial condition on alpha is that alpha is zero everywhere. This should guarantee a certain level of similarity to the pitzDaily case of pisoFoam. Viscosity is set to match the value of the pitzDaily case of pisoFoam, alos gravity is set to zero. I used in both cases the dynamicSmagorinsky LESModel of Alberto (https://github.com/AlbertoPa/dynamicSmagorinsky/) The qualitative behaviour looks similar to the results of pisoFoam, but I did no validation yet. What do you think of all this? |
June 15, 2012, 03:17 |
#42 |
Albrecht vBoetticher
Rep Power: 17 |
Looks good to me so far. I am looking forward to someone validating your code with DNS or Experimental Data.
Maybe a possible step would be to ask Saffari/Hosseinnia for their OpenFOAM model they used in "Two-phase Euler-Lagrange CFD simulation of evaporative cooling in a Wind Tower" In: Energy and Buildings, vol. 41 issue 9, 2009, and compare your simulation to their figure 6 which compares the simulation with analytical data. The setup allows to compare lots of single aspects like drop size, velocity, tower diameter etc. In September it will be decided if my project treating sediment transport is accepted, if yes I will try out your code. |
November 9, 2013, 02:18 |
#43 | |
mrityunjay sahu
Rep Power: 13 |
I have tried the file pitzDailyTwoPhaseLES. However I am getting following error: --> FOAM FATAL IO ERROR: keyword Ct is undefined in dictionary "/home/mj/Desktop/twoPhaseEulerFoamLES/constant/transportProperties" file: /home/mj/Desktop/twoPhaseEulerFoamLES/constant/transportProperties from line 21 to line 41. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting I am new to OpenFOAM kindly advised. |
November 11, 2013, 04:07 |
#44 | |
Gerhard Holzinger
Rep Power: 28 |
The error message says, that you need to specify a constant named "Ct" in the file transportProperties. Believe it or not, most of the times the error messages reported by OpenFOAM are very meaningful. |
November 16, 2017, 22:48 |
#45 | |
Rep Power: 14 |
Dear Alberto,
Do you have any publication using LES twoPhaseEulerFoam for me to refer to? Thanks! OFFO Quote:
