April 14, 2009, 05:59 |
buoyantSimpleFoam with LaunderSharmaKE
Marco Müller
Rep Power: 17 |
Hi All,
I'm trying to simulate the case described here: http://cfd.mace.manchester.ac.uk/cgi...&0&0&0&unknown The W direction is resolved with 6 elements. The solution progresses well except of Turbulence equations!! Residuals there stick at 0.1-0.4... (Low-Re has to be used!!?) The result is that velocities are much too small (~0.3 mm/s), but qualitatively right. Heat Transfer is without convection... Turbulence quantities have zeroGradient BC's, for "p" and "pd" I wasn't sure what to use. Currently it is "wallBuoyantPressure, uniform 1 bar" for p (calculated, uniform 1 bar" gave same results) and "fixedFluxBuoyantPressure, uniform 0" for pd! Any suggestions? Is there any other solver/turbulence model for that problem?? Thanks in advance Marco |
April 16, 2009, 02:53 |
Marco Müller
Rep Power: 17 |
Ok, some update:
with 1e-10 for BC values for turbulence quantities it converges better, but the flow is even slower!! Marco |
April 21, 2009, 07:17 |
Update
Marco Müller
Rep Power: 17 |
Hi again,
I hope that someone can help. First of all, I made a failure in mesh: The thin direction now is resolved with 150 cells (LowRE), the height is 250 cells and the third direction 5 cells. That sounds stupid, but for CFX (sorry) it works perfect and some professionals (Menter..) chose an even worser resolution... Here are the compared results: bild.png (CFX results with SST model) As you can see, the results are the same for 50% height and 10% height with OpenFOAM. The flow is too slow, turbulence switched of seems to change nothing... Here is the case: BuoyantCavity.tar.gz Thanks for your help Marco |
BuoyantSimpleFoam tutorial error | erydj | OpenFOAM Installation | 2 | June 23, 2011 06:46 |
BuoyantSimpleFoam | amitshah | OpenFOAM Running, Solving & CFD | 4 | June 3, 2009 07:04 |
buoyantSimpleFoam Message error | Khelian973 | OpenFOAM Running, Solving & CFD | 8 | June 2, 2009 14:26 |
buoyantSimpleFoam error message | Khelian973 | OpenFOAM Running, Solving & CFD | 4 | April 16, 2009 05:45 |
BuoyantSimpleFoam Channel problem | prashant24983 | OpenFOAM Running, Solving & CFD | 7 | September 18, 2008 05:50 |
