Struggling with BCs for 'simple' interFoam case
Old   April 7, 2009, 04:48
Default Struggling with BCs for 'simple' interFoam case
rassilon is on a distinguished road
Hi folks,
I am trying to model a simple cube, half filled with fluid 3 x 3 x 3 units in size. The top is open to atmosphere, and the centre unit on the base is an inlet. I am trying to develop a uniform, low pressure input via the inlet to create ripples and bubbles on the surface of the fluid.
I am really struggling to get the boundary conditions correct for this, as I am using interFoam, and trying to juggle boundary conditions in gamma, pd and U files within the 0 directory. At the moment I have the following conditions:
Gamma
nozzle
type inletOutlet;
inletValue uniform 1;
value uniform 1;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
pd
nozzle
type inletOutlet
value uniform 1;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho none;
psi none;
gamma 1;
value uniform 0;
U
nozzle
type pressureInletOutletVelocity;
phi phi;
value uniform (0 0 0)
atmosphere
phi phi;
I receive an error message each time I attempt to run the solver:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type pressureInletVelocity)
on patch nozzle of field pd in file "/home/swervo/OpenFOAM/nathan-1.5/run/tutorials/Asai_Models/cube_experiments/cube_1-1/0/pd"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692.
FOAM exiting
So what am I doing wrong? I thought this would be reasonably simple to get going, but is proving to be anything but! Any help would be greatly appreciated.
Many thanks,
N
rassilon is offline   Reply With Quote
Old   May 15, 2009, 11:16
Daniele
dani is on a distinguished road
Send a message via MSN to dani
Hi!
can I ask you the meaning of " value uniform 0 " in:
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho none;
psi none;
gamma 1;
value uniform 0;
And why is it necessary specify phi, rho, psi, gamma (even if p0 is the only required entry on the User Guide (pag. U-129) for totalPressure) ?
Thanks
dani
dani is offline   Reply With Quote
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Exporting BC's from one case file to another Mazyar FLUENT 3 April 22, 2006 06:03
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 10:50
