GGI in OpenFOAM
Old   March 1, 2010, 09:04
Nick Gardiner
NickG is on a distinguished road
Three time steps that is, not iterations!
NickG is offline   Reply With Quote
Old   March 1, 2010, 09:34
Nick Gardiner
I think that I've worked out the problem - the mesh is in metres not mm so is 1000 larger than wanted, causing the speed at the edge to be a lot larger than expected. Does anyone know if I can change the mesh size simply by just dropping a factor of some sort into the points file?
Old   March 1, 2010, 09:35
Pavan
rieuk is on a distinguished road
Good to hear. Should be easy to do - if you import from Gambit then you can put a scaling factor as an argument to gambitToFoam
rieuk is offline   Reply With Quote
Old   March 1, 2010, 10:14
Nick Gardiner
I'm coming from pointwise straight as an openfoam mesh, so in future I'll need to sort it out there. In the end I copied and pasted into OpenOffice, factored it down and copied it back, which works until about the 19th step when the velocity shoots up and I get another floating point error. Any suggestions from the case files?
Thanks
Nick
Old   March 2, 2010, 04:09
flo
champet
flo is on a distinguished road
Hi Nick,
use
transformPoints –scale ‘(0.001 0.001 0.001)’ to scale m to mm
Have a good day,
Flo
flo is offline   Reply With Quote
Old   March 2, 2010, 11:41
Nick Gardiner
Thanks flo it certainly saves some time
Nick
Old   March 2, 2010, 12:44
Alberto Passalacqua
Great job! :-)
Alberto Passalacqua
Old   March 6, 2010, 08:14
Pavan
Hey guys,
How do use GGI for a variable rotation rate (sinusoidal)?
Cheers
Old   March 6, 2010, 10:23
Simon Lapointe
Simon Lapointe is on a distinguished road
You can easily modify the mixerGviFvMesh class to specify an oscillating motion instead of a fixed rpm.
Simon Lapointe is offline   Reply With Quote
Old   April 8, 2010, 09:38
Default GGI and interDyMFoam: moving element in a liquid phase
  #50
Antoine Devesa
A.Devesa is on a distinguished road
Dear all,
i'd like to ask for some advice for two small questions concerning interDyMFoam and GGI.
My case is a sort of mixer, full to 1/3 of it with water, the rest being air. I have a moving element far away from my phase frontier, quite at the bottom of the mixer, modeled with GGI. Everything except my GGI interfaces is defined as wall.
1- I observe quite high velocities (1m/s) in the vicinity of the interface between the two phases, after just one time step, which is quite surprising since everything is at rest at the beginning. The problem is that those high velocities close to the interface stay there afterwards, if i simulate longer. Can anyone tell me where does this come, and how to circumvent that if possible?
2- I would expect to find velocities close to my "rotor" of the order of the velocity introduced by the rotor motion itself. Instead of that, they remain ~3 orders of magnitude smaller than those, as if the liquid were not pushed or put in motion by the rotation movement... Is there a direct link with my density ratio, due to false definition of my fluids? Do i do something false concerning the BC in the moving region, of my walls? Did i miss something to set up for GGI multiphase simulations?
Since these are my first multiphase simulations, and almost my first GGI ones, i would be grateful for any idea, comment,...! Thanks!
A.Devesa is offline   Reply With Quote
Old   April 8, 2010, 10:12
Nick Gardiner
Hi Antoine
1. - If I didn't have a fine enough mesh I found my velocity went up quickly and kept going until I got a floating point exception. With finer meshes it went up to start with but then settled back down after a several degrees of rotation. ...so have you tried a finer mesh?
2. - If you imported your mesh - have you checked that is in mm not m?
Also is your time step small enough.
You may have to play around a bit but I hope this helps.
Nick
Old   April 8, 2010, 10:21
Pavan
@Antoine
also make sure the ggi part and the static parts of the mesh are being merged properly ie. Make sure you created them such that they fit together perfectly
Old   April 8, 2010, 10:25
Antoine Devesa
Thanks Nick for your quick answer.
1- My mesh is indeed quite coarse but, still i would except that those peaks in velocity close to the interface vanish after some time, or am i just being too optimistic? In my case they are staying there and remain about the same order of magnitude...
2- My mesh was indeed imported, but the units are ok. The velocities i except are anyway based on the radius, so whatever the units may be, these should remain representative of the rotor motion. Don't you think?
Mh, do you have from your experience with all that - GGI + interDyMFoam - other suggestions? Thanks!!!
Old   April 8, 2010, 10:30
Antoine Devesa
Thanks for your reply James,
in fact, my GGI moving and sliding interfaces are fitting very perfectly (not only visually, but my ggiCheck shows it as well), i have roughly the same number of elements on them and the motion corresponds exactly to what i want.
My point 2 is: it's just as if the rotor were turning at the good velocity, but having no coupling on the fluid, which is rather very strange, and i can't explain...
It seems that my points 1 and 2 are due to very different things, but since it's related to GGI and interDyMFoam, i wanted to post them at the same time....
Old   April 8, 2010, 10:49
Antoine Devesa
Just as precision concerning point 1/:
i tried to simulate with sigma 0, and i still observe these high velocities in the vicinity of the interface, and mostly close to the walls.
May this precision give some ideas to you!...
Old   April 8, 2010, 13:11
Alberto Passalacqua
I do not know much of GGI, but what you are experiencing seems to be related to the interpolation across the interface. I had a similar problem in my multiphase code (euler-euler, not VOF).
A (partial) solution to the problem in my case is to include the rapidly changing source terms (pressure gradient, buoyancy, other body forces, phase interaction terms) in the Rhie-Chow formula.
Best,
Alberto Passalacqua
Old   April 9, 2010, 04:52
Antoine Devesa
I'm sorry, i've been flooding this thread a bit yesterday.
Mostly because the possible answer to my 2nd point was already written in the question + in the previous posts of this thread: i changed my BC for my rotor from wall to movingWallVelocity. It looks much more realistic now, though i still doubt if i really need to do that. I thought that the GGI treatment was not only to move the cells of the moving regions, but as well to adapt the boundary conditions.
Is it so, that i must not conserve my wall BC in the moving region and change them to movingWallVelocity? Isn't the code then trying to apply twice the wall conditions?
To my question about high velocities at the phase interface, i've been having no success with it yet, but i'll keep trying or flooding another thread since it's nothing to do with GGI...
Old   April 9, 2010, 05:12
Antoine Devesa
@Alberto
Best,
Grazie for this hint. In my case, i'm starting with everything at rest, so there should be no rapidly changing terms or gradients in the momentum equations. And since this behaviour is already after one time step to observe, i'm rather tiping on a problem with my BCs close to the phase interface (walls) or my schemes:
    div(rho*phi,U)   Gauss limitedLinearV       1;
    div(phi,gamma)   Gauss limitedLinear01      1;
    div(phirb,gamma) Gauss interfaceCompression  ;
    div(phi,omega)   Gauss upwind                ;
Old   April 9, 2010, 10:49
Alberto Passalacqua
Not so quickly. If the density gradient across the interface is big enough, and you have gravity turned on, that's rapidly changing.
Isn't there where you have the highest velocity gradient?
Best,
Alberto Passalacqua
Old   April 30, 2010, 09:30
Nick Gardiner
Alberto
How do you turn gravity on/off? Is it on by default?
I'm trying to rotate an empty 2D mesh 'cylinder' inside a tunnel with an inlet at one end and outlet at the other in order to find out the minimum ggi interface spacing needed. Like Antoine it blows up after ~20 timesteps even with a courant No. of 0.1. This is due to the rotation of the mesh creating a non-physical rotational velocity across the interface. Am I using the wrong method? Really I want the rotation of the mesh to have no effect on the cross flow as it is free of any obstructions (walls).
Nick
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
