Any example of manualCoeffs for decomposeParDict?
Old   April 1, 2009, 18:22
Red face Any example of manualCoeffs for decomposeParDict?
Hai Yu
yuhai is on a distinguished road
Hi, everybody,
Good Day.
I am now a little comfuse on decomposePar for turbDyMFoam, it always cut through the GGI interface.
So I want to decompose manually,
firstly, I tried to set the "procBoundaryXXtoYY" interfaces in Gambit, and convert them to Foam, problems are countered:
1, if fluentMeshToFoam converting 2D mesh, defaultFaces (frontandBackPlane in Gambit) are not set into groups.
2, if fluent3DMeshToFoam converting 2D mesh with z depth, "faceZones" and "pointZones" don't provide enough information for "cellProcAddressing" and "pointProcAddressing".
Then, I go to the "manualCoeffs" in decomposeParDict, but I can't find the example or explain of the grammar of the DataFile.
Can anybody give me any hints?
Thanks in advance.
Hai Yu
yuhai is offline   Reply With Quote
Old   April 19, 2009, 19:48
Default decomposeParDict & manualCoeffs
Axel Mohr
alexm is on a distinguished road
sorry, I have no answer, but the same question. I also would like to know more about the manualCoeffs data file in decomposeparDict. Its just about an old problem of getting a sharp interface of two phases with the snappyHexMesh tool.
I hope, someone can help us.
Greetings, Axel
alexm is offline   Reply With Quote
Old   July 22, 2009, 13:16
Julien Schaguene
Schag is on a distinguished road
Hi all,
I'm actually looking for the same thing.
Does anyone found an example or explanation/tutorial to do it?
Or eventually someone knows how to define precise cutting planes to separate regions in order to run in parallel without using manual option?
Thx,
Julien
Schag is offline   Reply With Quote
Old   May 11, 2010, 04:51
Valerio Novaresio
novyno is on a distinguished road
Hi All,
here you can find an example of a ManualDecompositionFile of a simple cube splitted in 8 elements. This file contains the same number of the mesh elements and the entries refer to the processor number. So in the example in attached the first and second elements are assigned to the processor0, etc...
...The best way to acquire new knowledge is to share it...
novyno is offline   Reply With Quote
Old   May 11, 2010, 04:53
Valerio Novaresio
Sorry... I can't attach the file... I put it here!
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class labelList;
location "constant";
object cellDecomposition;
8
0
0
1
1
1
1
0
0
Old   June 30, 2015, 14:11
Adriano
AdrianoCT is on a distinguished road
Hy guys,
is it possible do a CellDecomposition from cellSet? I have to manage 15 mln of cells, so isn't convenient split the domain manually.
Any suggestions? Thanks
AdrianoCT is offline   Reply With Quote
Old   July 21, 2015, 11:51
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Originally Posted by AdrianoCT View Post
Hy guys,
Yes, it is not obvious but here's how I managed to do it:
run topoSet to create a faceSet from a cellSet using the faceSet cellToFace option.
Here's an example of the topoSetDict (where you should have created a cellSet):
       name    myFaceSet;
       type    faceSet;
       action    new;
       source    cellToFace;
       sourceInfo
       set myCellZone;
       option all;
you can then run a decomposePar with the singleProcessorFaceSets command. You may want to also include both your cyclic patches in the singleProcessorFaceSets command if you are doing this for an AMI simulation...
-Louis
louisgag is offline   Reply With Quote
