Appropriate model for turbulent, steady state pipe elbow flow
Old   March 21, 2009, 10:22
Default Appropriate model for turbulent, steady state pipe elbow flow
Milos Stanic
milos is on a distinguished road
Hi everyone!
Ok, here's the deal: I am investigating a case of turbulent, steady state pipe elbow flow or to be more precise, pressure drops due to pipe elbows (DN 50). Now, I believe that the best solver for this kind of thing is simpleFoam, but the thing is that I don't get the appropriate stream (velocity vector) vortices in the elbow. I do get the vortices, but they start appearing after the elbow, not in the elbow as the experience tells us.
I attached an example pic named U_vortices.jpg from one science projects I found done in Fluent. Notice that the text beneath the pic says it is elbow-MIDSECTION (45 deg or half-way through the elbow). I actually used very similar parameters of the flow as in that simulation, which includes: Re around 540000, with water as a fluid (nu at 20 deg C = 1.004e-6).
Now take a look my other attachment named Stream 1.jpg , which is what I got.
Where's the catch?
My pressure BC's are:
inlet - zeroGradient
outlet - fixedValue (0)
wall - zeroGradient
My velocity BC's are:
inlet - fixedValue (10 0 0)
outlet - zeroGradient
wall - fixedValue (0 0 0)
Thanx!
Milos
milos is offline   Reply With Quote
Old   March 24, 2009, 18:30
Default Make the images really comparable :-)
gskillas is on a distinguished road
Hello Milos
could you also make a plot similar to U_vortices.jpg? I find it very hard to compare your data with the Fluent simulation... I even suspect that they might be closer than youŽd think at first glance.
Regards,
George
gskillas is offline   Reply With Quote
Old   March 25, 2009, 10:08
Milos Stanic
Thnx for the reply George.
After several hours of roaming through ParaView I found the option that provided me with the speed intensity scalars (namely: Ux, Uy, Uz), which in addition gave me the attached photo. I guess I was really close all the time...
The thing is just that the guy, who has done the example simulation in Fluent, actually drew, as it states beneath his figure - IN-PLANE velocity VECTORS. I'm not sure whether I can do a similar thing in ParaView... Does anyone know how to do that in ParaView? The closest I got was graphing the speed component intensity as a scalar.
Old   July 7, 2009, 12:09
Question
kjetil is on a distinguished road
Originally Posted by milos View Post
Hi everyone!
wall - zeroGradient
Thanx!
Milos
I'm on a quest for pipe simulation myself - and would like to know what files you keep in your '0' directory for this kind of simulation? The tutorials I have been looking through all seem to use gases - and I wonder if I can simplify the setup using a fluid (water)? The problem is that my simulation using simpleFoam is very very slow, basing it upon a previous gas-case tutorial.
kjetil is offline   Reply With Quote
Old   July 9, 2009, 03:24
Milos Stanic
I used simpleFoam solver, since it is for incompressible flows... I simply used the files from the tutorial folder.
High speed compressible flow through pipe Munni Main CFD Forum 6 December 7, 2015 12:33
Mixture model - pipe flow Aly FLUENT 10 June 21, 2010 14:50
Steady state Inlet port flow analysis Zamir Rashid Siemens 1 May 21, 2006 12:47
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
