January 23, 2003, 07:41 |
I would like to know, if it i
I would like to know, if it is possible in the post-proccesing phase, to get e.g. the stress or temperature in a CV, only by clicking on it or something similar. So far I have used the graph functionality, but I would like to know the "exact" numerical value.
January 23, 2003, 08:10 |
Which postprocessor are you u
Which postprocessor are you using?
January 23, 2003, 08:24 |
I am using OpenDX(dxFoam) whi
I am using OpenDX(dxFoam) which follows with the FOAM 2.1 release.
January 23, 2003, 08:29 |
Unfortunately no such facility
Unfortunately no such facility is easily available in DX. I don't know whether other postprocessors provide this information.
In foam2.1 there is a command line utility 'lineSample' which can answer these questions for you. It needs a 'lineSampleDict' dictionary in the system/ directory of the case where you specify coordinates of the sampling lines, the fields to sample and the interpolation to use. It outputs a Matlab format file in a Matlab/ directory. Below an example where I get a value somewhere at the top-right of the lid-driven cavity. Note that this utility is currently under a drastic rewrite for Foam2.2 // lineSample dictionary // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // version 0.5; format ascii; root "/users/tfd/ljus/foam/run"; case "channel1"; instance "system"; local ""; class dictionary; object sampleDict; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // cell: use only cell-centre value; constant over cell // cellPoint: use cell-centre and vertex values // cellPointFace: use cell-centre, vertex and face values interpolationSchemes { p cellPoint; U cellPoint; } /* format of the sampling line: */ samplingLines ( (0.099 0.099 0.005) (0.0991 0.099 0.005) 2 zero "y" "full" ); scalarFields ( p ); vectorFields ( U ); // ************************************************** *********************** // |
January 28, 2003, 12:33 |
If you want to monitor a loca
If you want to monitor a location during running you can also add 'probes' to your application. See e.g. the oodles application. The probe locations are specified in a constant/probeLocations dictionary and every time step the value at each of the locations will be written to a probes/ directory.
February 3, 2003, 07:35 |
Thank you very much for your
Thank you very much for your help!
Ensight - node values -cell values | leo | FLUENT | 1 | May 12, 2010 08:47 |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 01:22 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 08:56 |
time dependent MRF ? | olivier | Main CFD Forum | 1 | April 1, 2005 10:28 |
two dependent properies | Neser | CFX | 0 | February 20, 2005 17:33 |
