Problems with startTime latestTime
Old   February 16, 2005, 09:13
Default Where does runTime.writeObjec
Marco Kupiainen (Kupiainen)
Where does runTime.writeObjects() look for what to write to file? I am currently trying to keep running a case from the latest time I computed, but discovered that the variables needed in initial data
B muSgs muTilda
are not saved. Where does one control what variables are saved in each timestep?
best regards
Marco
Old   February 16, 2005, 09:21
Default When you create each IOobject
Hrvoje Jasak (Hjasak)
When you create each IOobject you need to specify the properties which include NO_WRITE or AUTO_WRITE.
For example:
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
runTime,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
If you want things to be written with runTime.writeObjects(), find where they are created and specify IOobject::AUTO_WRITE.
Alternatively, set the auto-write on IOobject (see the appropriate header) using the writeOpt() member.
Enjoy,
Hrv
Old   February 16, 2005, 09:51
Default It seems that the program doe
It seems that the program doesn't do what it is supposed to do:
in e.g. ..../src/LESmodels/compressible/GenEddyVisc.C
muSgs_
IOobject
"muSgs",
runTime_.timeName(),
runTime_,
mesh_
the AUTO_WRITE is on, but still no output. Similarily with the other variables I am looking for. You mentioned something with setting the auto-write on IOobject using the writeOpt() member. How does one do this in practice?
M.
Old   February 16, 2005, 10:17
Default muSgs_.writeOpt() = IOobject:
Mattijs Janssens (Mattijs)
muSgs_.writeOpt() = IOobject::AUTO_WRITE;
(haven't checked)
Mattijs
Old   February 16, 2005, 10:41
Default This is weird, I wrote and ra
Eugene de Villiers (Eugene)
This is weird, I wrote and ran that LES code and it worked fine originally; I have the results to prove it.
What model are you running? I know of none that will solve for muSgs, muTilda and B as you seem to imply. Only Spalart-Allmaras will dump mutilda and only ReynoldsStress will dump B. What code did you use to compute the latest time? I suspect it wasnt the same code with the same LES models that you are trying to restart.
Note, oodles and coodles use different variables.
Old   February 16, 2005, 11:50
Default I'm using coodles with the 1-
I'm using coodles with the 1-eqn model. It needs B and muSgs and muTilda in order to start.
This is also the same code I'm trying to restart.
Old   February 16, 2005, 11:59
Default Maybe stupid question: do you
Maybe stupid question: do you have your writeInterval set? writeObjects() only dumps changed variables and only if the writeInterval time has come.
If you want to force it just add it to coodles.C just before the writeObjects call.
Mattijs
Old   February 16, 2005, 12:07
Default This is how my controlDict lo
This is how my controlDict looks like:
applicationClass coodles;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 1;
deltaT 1e-07;
writeControl timeStep;
writeInterval 100;
cycleWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
but
h04n05:~>ls 0/
B T U k muSgs muTilda p
h04n05:~>ls 5e-05/
T U U_0 k k_0 p p_0 phi phi_0 rho rho_0 time
The other variables are printed, but not the turbulence model variables...
Marco
Old   February 16, 2005, 12:14
Default While trying to make the code
While trying to make the code force writing by adding
muSgs.writeOpt() = IOobject::AUTO_WRITE;
muTilda.writeOpt() = IOobject::AUTO_WRITE;
B.writeOpt() = IOobject::AUTO_WRITE;
runTime.writeObjects();
to the coodles.C. However muSgs, muTilda and B are undefined giving rise to compiling errors...
coodles.C(73): error: identifier "muSgs" is undefined
coodles.C(74): error: identifier "muTilda" is undefined
coodles.C(75): error: identifier "B" is undefined
What to do?
Old   February 16, 2005, 12:19
Default The one-equation SGS model on
The one-equation SGS model only needs muSgs and k to restart. Check GenEddyVisc.C which is the base class for oneEqEddy. FoamX just creates all the possible fields a SGS model could use, thats why they appear in your starting time directory.
Change
writeInterval 10;
In your controlDict to write out data after 10 timesteps.
Old   February 16, 2005, 12:22
Default turbulence->muSgs()().writeOp
  #11
turbulence->muSgs()().writeOpt() = IOobject::AUTO_WRITE;
So
- get the muSgs field from the turbulence model
- use an extra bracket pair to get access to the raw volScalarField
- apply writeOpt()
Old   February 16, 2005, 12:40
Default Added turbulence->muSgs()
  #12
Added
and now the code compiles, but to no vein. Problem still persists :-(
h04n05:~>ls 0/
h04n05:~>ls 1e-07/
T U k p p_0 phi rho time
h04n05:~>ls 2e-07/
I have already looked in the ..../src/LESmodels/compressible/GenEddyVisc.C
and everything is correct there. I really don't have any clues any more. There is something wrong with the code anyway, so much is clear to me.
Old   February 16, 2005, 12:46
Default Curiouser and curiouser. I
  #13
If what Mattijs suggets doesnt work (the object was created using AUTO_WRITE after all), you can write the file using a more brute-force approach:
Near the bottom of your top level code put:
if(runTime.outputTime())
turbulence->muSgs()().write();
The real question is: "why is it not working in the first place?" All the code seems to be in order.
Old   February 16, 2005, 12:53
Default Hmm, all of this should have
  #14
Hmm, all of this should have worked first time anyway and it's not too surprising that AUTO_WRITE; did not do the trick. I don't fancy digging through it myself but this is what you do:
switch on database debugging in ~/.OpenFOAM-1.0/controlDict:
database 1;
in the DebugSwitches section. Database will now tell you everything. :-)
I have checked the oodles tutorial and all is well (that's worth doing on your installation as well.
My guess is that due to a cock-up there are two IOobjects with the same name nuSgs, which messes up the database.
A progress report would be nice :-)
Hrv
Old   February 17, 2005, 20:19
Default B T U k muSgs muTilda p are t
  #15
Henry Weller (Henry)
B T U k muSgs muTilda p are the fields FoamX writes out but not all are used, it depends on the choice of model. e.g. muTilda is only used by SpalartAllmares and hence is not written by during the code run unless you choose the SpalartAllmares model. So everything should be fine for restarting, is that the case? What missing fields is the code looking for during restart?
There will however be a problem running FoamX on the timesteps dumped by the code because it will expect these extra fields. The simple way out of this problem is to copy the missing fields (which are not used by the code) to the from the 0 directory to the timestep of interest. We will look into this limitation of FoamX in the future.
Old   February 18, 2005, 03:52
Default It is looking for muSgs.
  #16
Old   February 18, 2005, 04:23
Default > I'm using coodles with the
  #17
> I'm using coodles with the 1-eqn model. It needs B > and muSgs and muTilda in order to start.
Are you sure it needs all these three in order to start? muTilda is only used by the SpalartAllmares and you say you are running the 1-eq model.
Old   February 18, 2005, 04:48
Default I have just run coodles on th
  #18
I have just run coodles on the tutorial case and I get k k_0 muSgs p p_0 phi phi_0 rho rho_0 T time U U_0 dumped in the time directories and the restart is fine. The problem you are seeing appears to be a platform-dependent database registration failure. We have never seen such a problem on Linux but something possibly similar happened on the Itanium machine using the Intel compiler. What platfor and compiler are you using?
Old   February 18, 2005, 08:22
Default It is an Itanium 2 platform,
  #19
It is an Itanium 2 platform, using Intel compiler
icpc 8.1.026 with -gcc-version=330 flag.
Old   February 18, 2005, 08:52
Default OK then it does appear to be
  #20
OK then it does appear to be the problem seen before which is associated with the Intel compiler optimiser for the Itanium 2. I might be able to find a work-around but it might be better if you use gcc-3.4.3 instead which we know produces an exectuable which runs correctly on the Itanium 2.
DieselFoam does not restart from latestTime lord_kossity OpenFOAM Bugs 8 February 21, 2009 14:54
Problems with Fluent on simple 1D problems agg FLUENT 3 November 21, 2008 12:55
cfx problems on net ripudaman CFX 0 October 20, 2008 04:06
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 05:02
problems in UDS selva FLUENT 0 September 18, 2006 01:07
