What must be defined in fvSolution
Old   February 21, 2005, 05:10
Default --> FOAM FATAL IO ERROR : ke
Marco Kupiainen (Kupiainen)
--> FOAM FATAL IO ERROR : keyword (psi*p) is undefined in dictionary "/afs/nada.kth.se/home/nada/marcok/PDC/sonicOodles/base/system/fvSolution::solvers"
file: /afs/nada.kth.se/home/nada/marcok/PDC/sonicOodles/base/system/fvSolution::solvers from line 27 to line 34.
Function: dictionary::lookupEntry(const word& keyword) const
in file: db/dictionary/dictionary.C at line: 144.
FOAM exiting
What does this mean? I do not have any div psi*p in my equations. Not at least that I'm avare of. What should I do?
Old   February 21, 2005, 06:03
Default It says that you are trying t
Hrvoje Jasak (Hjasak)
It says that you are trying to solve an equation for the variable called (psi*p) and that in your case "base", in the solvers section of the system/fvSolution dictionary you did not define which solver to use.
To be more precise, the variable you are trying to solve for (rho, by the looks of things), has been created automatically (sounds dubious, you may have already lost the oldTime() and similar, depending on the precise nature of error you've made) rather than being named. I would suggest looking at sonicFoam in detail, especially at the bottom of the createFields.H
volScalarField rho
IOobject
"rho",
runTime.timeName(),
runTime
psi*p
See, this one is named!
Enjoy,
Hrv
FvSolution pRefCell and pRefValue maka OpenFOAM Pre-Processing 5 February 17, 2015 04:00
General help for fvSchemes and fvSolution settings harly OpenFOAM Running, Solving & CFD 4 September 7, 2009 11:31
Programmatically create fvSolution dictionary cliffoi OpenFOAM Running, Solving & CFD 14 February 12, 2009 03:50
User defined bc anja OpenFOAM Running, Solving & CFD 20 June 6, 2008 13:12
User Defined GUI Frederik FLUENT 0 June 23, 2006 17:12
