Fluid wall shear stress
Old   March 3, 2005, 08:50
Default I am trying to calculate the w
Sinead Kelly (Kelly)
I am trying to calculate the wall shear stress within a fluid in a cylindrical pipe. I have defined WSS as a volVectorField in a createFields.H file, so that I can look at the wall shear stress in dxFoam. The code I have been using for the wall shear stress is:
label patchA = mesh.boundaryMesh().findPatchID("wall");
fixedValueFvPatchVectorField& wallshearstress =
refCast(WSS.boundaryField()[patchA]);
forAll(wallshearstress, patchFaceA)
volTensorField gradU = fvc::grad(U);
volTensorField shear = mu*(gradU + gradU.T());
shear[patchFaceA].component(tensor::XX) = 0;
shear[patchFaceA].component(tensor::YY) = 0;
shear[patchFaceA].component(tensor::ZZ) = 0;
wallshearstress[patchFaceA].component(vector::X) = shear[patchFaceA].component(tensor::XY) + shear[patchFaceA].component(tensor::XZ));
wallshearstress[patchFaceA].component(vector::Y) = shear[patchFaceA].component(tensor::YX) + shear[patchFaceA].component(tensor::YZ)
wallshearstress[patchFaceA].component(vector::Z) = shear[patchFaceA].component(tensor::ZX) + shear[patchFaceA].component(tensor::ZY);
So, I have been able to get the stress tensor and set the 3 normal components to zero. I have then added the 2 X components to get the overall X component of the shear stress, added the 2 Y components etc.
However, looking at my results in dxFoam, the WSS vectors are not aligned correctly along the wall of the cylinder.
Do I have to project my stress vector onto my surface and does anyone have any idea how to do this? Has anyone written a code to calculate the wall shear stress of a fluid already? Thanks,
Sinead
Old   March 3, 2005, 08:56
Default You might find the applicatio
Henry Weller (Henry)
You might find the application
applications/utilities/postProcessing/wall/wallShearStress
useful. Simply replace R in the expressions with your shear field and it should do what you want.
Old   March 30, 2011, 07:41
T.D. is on a distinguished road
hi henry,
what do you mean by "R" in the expressions where?
thanks
T.D. is offline   Reply With Quote
How to get the wall shear stress by UDF Chen Fangzhi FLUENT 3 November 11, 2014 07:03
wall shear stress in UDF elisa FLUENT 1 August 13, 2008 09:36
wall shear stress Todd FLUENT 0 April 28, 2008 14:51
UDF for wall shear stress Bastian FLUENT 0 July 21, 2004 05:52
wall shear stress lingo FLUENT 2 June 2, 2003 04:40
