May 28, 2011, 06:01 |
#21 |
Gijsbert Wierink
Rep Power: 18 |
Hi Hector,
Zeljko Tukovic and Hrvoje Jasak have published a conference paper that may be interesting for you: Simulation of free-rising bubble with soluble surfactant using moving mesh finite volume/area method.
Regards, Gijs |
May 30, 2011, 15:23 |
#22 |
Hector Redal
Rep Power: 17 |
Hello Gijs,
I have tried to follow the link you had provided to me, but it seems to be broken. I am trying the following link: http://www.cfd-online.com/Forums/pow...rs/CFD2008.pdf Is this the correct link? Thanks in advance for your help and support. Hector. |
May 31, 2011, 02:40 |
#23 |
Gijsbert Wierink
Rep Power: 18 |
Hi Hector,
Yep, this is the link (I put it in code brackets so you can just copy and paste it into you address bar): Code:
http://powerlab.fsb.hr/ped/kturbo/openfoam/papers/CFD2008.pdf
Regards, Gijs |
May 10, 2016, 03:15 |
#24 |
Arahata
Rep Power: 10 |
'interFoam' solver in openfoam uses VOF method. Has the 'Fornt tracking method' for interface simulation been done by FOAM?
Thank you in advance. |
%60GLIBCXX_349b not found OpenFOAM 141 | alberto | OpenFOAM Bugs | 18 | December 4, 2008 23:50 |
Another %60GLIBCXX_349b not found OpenFOAM 141 | benofm | OpenFOAM Bugs | 2 | August 23, 2007 22:59 |
Musig code in OpenFoam | in_flu_ence | OpenFOAM Running, Solving & CFD | 1 | February 25, 2007 16:47 |
Tree of the openfoam code | mhuening | OpenFOAM Installation | 3 | January 29, 2007 18:06 |
OpenFOAm 13 libfiniteVolumeso not found | evgenii | OpenFOAM Running, Solving & CFD | 2 | October 15, 2006 01:26 |
