Linking new class to solver
Old   April 25, 2005, 07:02
Default Hello, I would like write m
Markus Hartinger
hartinger is on a distinguished road
I would like write my own class to extend icoFoam.
The class is defined in deflection.H and deflection.C, which are in the same directory as the solver. I included deflection.C in Make/files.
That works fines and everything compiles as long as I dont want to call any member functions of that class. If i call one of them it returns
> In function 'main':
> :undefined reference to 'main::deflection::test()'
I assume, I need to inclucde some command in Make/options, but I couldn't figure out which one.
thank you
Markus
hartinger is offline   Reply With Quote
Old   April 25, 2005, 07:17
Default Hi again, reading the forum
Markus Hartinger
Hi again,
reading the forum helps. See the "namespace" thread.
I was putting the #include "deflection.H" into the main function, which i shouldn't do apparently, dunno why, though.
Sorry for this self-conversation
Markus
Old   April 25, 2005, 07:25
Default deflection.H contains declarat
henry is on a distinguished road
deflection.H contains declarations and deflection.C contains definitions which you compile outside the scope of main. Then you wish to use the classes/functions from within main but you need to tell the compiler that they are declared in a different scope which is done my including deflection.H in the file containing the main function but not inside the main function because that would change the scope of the classes/functions and hence give you the linkage error you had before.
henry is offline   Reply With Quote
Old   April 25, 2005, 07:36
Default thank you, i didn't think abou
Markus Hartinger
thank you, i didn't think about the scope
linking several faces Christian F. FLUENT 1 June 6, 2008 07:29
How to access solver fields from fvPatchField%2360Type derived class that defines BC kar OpenFOAM Running, Solving & CFD 0 February 29, 2008 13:41
Problem for linking hsing OpenFOAM Running, Solving & CFD 2 April 19, 2006 05:07
Linking fortran and c vasanth Main CFD Forum 3 January 29, 2005 13:38
linking the script Mavinakere FLUENT 0 September 12, 2002 12:57
