How to add an application to FoamX
Old   March 26, 2005, 09:24
Default I am learning how to add a use
liqiangnwpu
I am learning how to add a user defined application, and I copied the dielseFoam in /application/ and change the file names to MyFoam and compiled it successfully,the path is set as follows:
EXE= $(FOAM_APPBIN)/MyFoam
but when run FoamX after that, I can not find this application solver in the standard solver list in FoamX, what should/can do to add it to the standard application list?
Old   March 28, 2005, 08:41
Default Search the board for FOAMX_USE
Mattijs Janssens
mattijs is on a distinguished road
Search the board for FOAMX_USER_CONFIG and you should pick up a thread discussing how to do this.
good luck,
Mattijs
mattijs is offline   Reply With Quote
Old   May 3, 2005, 14:44
Default hi, 1-to add a user defined
chafi_fatima_zohra
hi,
1-to add a user defined application, i copied the icoFoam in /application/ and change the file name to buildingFoam , but when i compiled it, the path is set as follows:
EXE=$(FOAM_APPBIN)/icoFoam why?
because , i think that when compilation is made successfully, the true path is set as follows:
EXE=$(FOAM_APPBIN)/buildingFoam
can you explain me where is a problem
2- i must rename icoFoam.C to buildingFoam.C?(when i do this the code does not compile)
thank you
Old   May 3, 2005, 14:49
Default Have you edited Make/files to
henry is on a distinguished road
Have you edited Make/files to correspond to the new name of the application?
henry is offline   Reply With Quote
Old   May 3, 2005, 15:03
Default hi, no, i did not made edit
chafi_fatima_zohra
hi,
no, i did not made edition in Make/file.
then, i must edit Make/file and change $(FOAM_APPBIN)/icoFoam to $(FOAM_APPBIN)/buildingFoam?
I must remove the expression icoFoam and replace it by buildingFoam?
thank you
Old   May 3, 2005, 15:14
Default That would be a good start. I
That would be a good start. It would also be a good idea to use FOAM_USER_APPBIN rather than FOAM_APPBIN. By the way all this is covered in UserGuide.pdf which is supplied with the release and is also available from the web-site.
Old   May 3, 2005, 15:20
Default hi, thank you very much for
chafi_fatima_zohra
hi,
thank you very much for your help
bye
Old   May 4, 2005, 13:58
Default hi, i edited in Make/files fi
chafi_fatima_zohra
hi,
i edited in Make/files file :
EXE=$FOAM_USER_APPBIN/buildingFoam (note: buildingFoam is my application)
but when i do runFoamX, I can not find this application solver in the standard solver list in FoamX
can you explain me please where is the procedure to add it in standard solver list?
thank you
Old   May 4, 2005, 14:39
Default If you want to setup FoamX for
If you want to setup FoamX for your new solver you will have to create configuration files for it. Take a look at the configuration files for the standard applications in OpenFOAM-1.1/applications/utilities/preProcessing/FoamX/config/applications
Old   May 4, 2005, 15:33
Default hi, i copied all files with e
chafi_fatima_zohra
hi,
i copied all files with extension .cfg from icoFoam to buildingFoam and replaced icoFoam expression by buildinFoam ,then configuration files have been created, but buildingFoam solver not appear when runing FoamX.
why?
thank you
Old   May 4, 2005, 15:37
Default What is the path to the buildi
  #11
What is the path to the buildinFoam.cfg file?
Old   May 4, 2005, 15:47
Default hi, the path is OpenFOAM-1.
  #12
chafi_fatima_zohra
hi,
the path is OpenFOAM-1.1/applications/utilities/preProcessing/FoamX/config/applications/inco mpressible/buildingFoam
Old   May 4, 2005, 16:11
Default And inside that directory do y
  #13
And inside that directory do you have the file buildingFoam.cfg? And in that file you have an entry
executable buildingFoam;
Old   May 4, 2005, 16:37
Default hi, yes
  #14
chafi_fatima_zohra
hi,
yes
Old   May 5, 2005, 11:40
Default hi, my problem concerning t
  #15
chafi_fatima_zohra
hi,
my problem concerning to add my new application in FoamX is not resolved and i don't know why?
i configured all files , i have buildingFoam.cfg file and in that file, i have executable buildingFoam.
can you help me please?
thank's
Old   May 11, 2005, 14:00
Default hi, after configuration, my n
  #16
chafi_fatima_zohra
hi,
after configuration, my new application not appear.
thank's
Old   May 11, 2005, 14:41
Default I have no idea what you are do
  #17
I have no idea what you are doing wrong and I haven't got any spare time right now to investigate because I am busy preparing the next release, perhaps someone else can help you.
Old   May 25, 2005, 03:18
Default hi, chafi fatima zohra, maybe
  #18
MaJianfeng
yfjma is on a distinguished road
hi, chafi fatima zohra, maybe you can solve the problem as followings:
1. find the controlDic file in the path
home/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/
2. add the following sentence to the file
"$FOAM_RUN/tutorials/buildinFoam"
Good Luck!!
yfjma is offline   Reply With Quote
Which application to use ploceus OpenFOAM Running, Solving & CFD 1 December 7, 2005 20:41
MPI Application in HPC wendy Siemens 0 May 19, 2005 02:50
application of CFD REKHA FLUENT 1 January 13, 2005 02:25
application of cfd samuel R devadoss Main CFD Forum 0 March 15, 2004 05:38
Application Example 1 omondi CFX 1 January 31, 2002 12:15
