June 10, 2005, 15:31 |
Hi everybody. I'm new to openF
Rogério Oliveira
Hi everybody. I'm new to openFoam and Would like to solve a steady state turbulent flow for Newtonian fluid (water). Can someone tell me which solver I have to use. I read that simpleFoam is used for transient flows and simpleFoam is used for non-Newtonian fluids. Could I use simplefoam for Newtonian fluid or turbfoam for steady state simulation? Thanks in advance.
Rogério |
June 12, 2005, 18:34 |
You can use either solver.
Mattijs Janssens
Rep Power: 26 |
You might want to run simpleFoam first (is fast to reach some kind of steady-state flow) and then restart using turbFoam to make sure your flow is actually steady. |
June 13, 2005, 07:16 |
You might find it useful to go
Rep Power: 22 |
You might find it useful to go through the tutorials which will make it clear which solver is appropriate as well as helping you understand how to run OpenFOAM.
C programming question eg simpleFoam | marc_wattenberg | OpenFOAM Post-Processing | 3 | January 27, 2009 18:32 |
TurbFoam simpleFoam incompatible fields for operation | braennstroem | OpenFOAM Running, Solving & CFD | 0 | June 19, 2008 10:43 |
What if I use turbfoam instead of simplefoam what is steady turblence | lakeat | OpenFOAM Running, Solving & CFD | 4 | January 18, 2008 12:13 |
SimpleFoam result for turbFoam initialisation | philippose | OpenFOAM Running, Solving & CFD | 0 | November 26, 2006 10:24 |
Differences between simpleFoam an turbFoam | francois | OpenFOAM Running, Solving & CFD | 3 | November 15, 2005 14:03 |
