Problems with a new solver
Old   June 7, 2005, 11:54
Default hi all, i have created a ne
chris10
hi all,
i have created a new solver and i have compiled it successfully, but when i tried to calculate an example i get the following errors:
free(): invalid pointer 0x80b7400!
free(): invalid pointer 0x80b9d78!
free(): invalid pointer 0x80bcb30!
free(): invalid pointer 0x80be000!
free(): invalid pointer 0x80ba2b8!
free(): invalid pointer 0x80b9a38!
free(): invalid pointer 0x80b9a78!
free(): invalid pointer 0x80bdaa8!
free(): invalid pointer 0x80bc590!
Segmentation fault
The adresses of the invalid pointers are always the same, so i think it is a static problem.
who can help me?
Old   June 7, 2005, 12:39
Default 1. Can you run one of the stan
Mattijs Janssens
mattijs is on a distinguished road
1. Can you run one of the standard solvers?
2. Create a copy of one of the standard solvers e.g. icoFoam and compile this and see if you get the same.
3. Is your gcc the one supplied by us or your system one?
mattijs is offline   Reply With Quote
Old   June 7, 2005, 12:54
Default 1. yes i can run the standard
chris10
1. yes i can run the standard solvers.
2. if i compile a standard solver with my gcc i get the same results. so i think the reason for the errors is my gcc.
thanks for your support!
Old   June 14, 2005, 07:21
Default hi, i have created a new s
chris10
hi,
i have created a new solver for incompressible flow and i have compiled it successfully, but when i tried to calculate an example i get the following error:
--> FOAM FATAL ERROR :
request for volScalarField rho from objectRegistry region0 failed
available objects of type volScalarField are
i want to calculate incompressible flows, so i donīt need the "volScalarFiels rho". so my qurstion is, which file needs the density?
Old   June 14, 2005, 07:25
Default What models and boundary condi
henry is on a distinguished road
What models and boundary conditions are you using?
When do you get this message? i.e. what is the code doing at the time?
henry is offline   Reply With Quote
Old   June 14, 2005, 10:24
Default i started with icoFoam (incomp
chris10
i started with icoFoam (incompressible, no turbulence model) and i combined it with buoyantFoam.
boundary conditions: T: fixedValue/zeroGradient,
p-WallBuoyantPressure,
U-fixedValue
i get the message at the first time step:
Starting time loop
Max Courant Number = 0
Time = 10
BICCG: Solving for T, Initial residual = 1, Final residual = 2.50922e-07, No Iterations 6
6
p
div(phi)
A(U)
1|A(U)
T_0
T
Function: objectRegistry::lookupObject<type>(const word&) const
in file: /home/dm2/henry/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line: 122.
FOAM aborting
Old   June 14, 2005, 10:51
Default > p-WallBuoyantPressure I w
I wrote this boundary condition for the buoyantFoam and related codes and because these are compressible (variable-density) codes this BC needs the density.
Old   June 14, 2005, 11:10
Default why do the pressure in incompr
chris10
why do the pressure in incompressilbe flows have the dimension [0 2 -2 0 0 0 0] (icoFoam) and in compressible flows [1 -1 -2 0 0 0 0] (buoyantFoam)? Did you set the density to 1 and divided the pressure by the density?
Old   June 14, 2005, 11:16
Default The pressure is divided by the
The pressure is divided by the density in the single-phase incompressible solvers but this does not imply the density is 1 only that is it constant and uniform.
Old   June 14, 2005, 11:44
Default now i have a new problem: i h
chris10
i have three output variables, but only the values of one were written in the runtime directory, the other files look like the initial files at runtime 0.
what did i wrong? should i AUTO_WRITE change to MUST_WRITE?
Problems about compiling a new solver fw407 OpenFOAM Running, Solving & CFD 1 December 27, 2007 14:52
Solver problems JV Siemens 0 October 28, 2005 00:31
Problems with VOF solver Benjamin FLUENT 0 August 20, 2004 09:17
Solver Software (?) problems JvK CFX 5 August 9, 2002 14:33
Solving 2-d problems by 3-d solver eddy Main CFD Forum 3 September 7, 2000 07:15
