Diagonally preconditioned biconjugate gradient
Old   June 14, 2005, 13:55
Default Hi, I would like to know wh
Billy
billy is on a distinguished road
I would like to know what are the major diferences between "Diagonally preconditioned biconjugate gradient" and the "Incomplete-Cholesky preconditioned biconjugate gradient" solvers.
Billy.
billy is offline   Reply With Quote
Old   June 14, 2005, 14:16
Default There's some brief technical i
Chris Greenshields
chris is on a distinguished road
There's some brief technical info at the following link [paper page 41, PDF page 47]:
http://www-2.cs.cmu.edu/~quake-paper...e-gradient.pdf
chris is offline   Reply With Quote
Old   June 14, 2005, 16:20
Default Hi Billy, This is to do wit
Hrvoje Jasak
Hi Billy,
This is to do with parallelism. Basically, you can do various kinds of preconditioning with the Conjugate Gradient solver. If you do nothing, the solver is a disaster.
The "best" kind of preconditioning we've got in FOAM is the Incomplete Cholesky. However, the preconditioner works by visiting rows of the matrix (cells) in a particular order and the efficiency of preconditioning depends on that order.
All is well when you're doing simulations on a single CPU. However, when you do a decomposition in parallel, each CPU needs to do its own preconditioning on the local cells (because the cells on other processors cannot be accessed (in order). Therefore, for a parallel run, the incomplete Cholesky preconditioning (ICCG) will give you a slightly different result than the identical run in serial (number of solver iterations may be slightly larger and you get different round-off).
Diagonal preconditioning, on the other hand, does not depend on the ordering of cells, but is much (well, hmm) worse than ICCG. Therefore, when doing single-CPU runs, you really have no reason to run anything else than ICCG (maybe AMG, but that's another, and painful, topic).
However, sometimes you can get into a situation when you absolutely desperately need the same result in parallel and serial, e.g. when chasing bugs. :-) In that case, using Diagonal preconditioning (DCG) will allow you to do that, but you'll pay with the increased simulation time.
Enjoy,
Hrv
Hrvoje Jasak
Preconditioned Conjugate Gradient Solver! Chidu Main CFD Forum 1 January 21, 2004 12:43
Help with Biconjugate Gradient to solve a system Isa Main CFD Forum 2 December 20, 2003 08:19
Preconditioned Gmres carlos Main CFD Forum 2 April 14, 2003 06:24
Diagonally Implicit Runge Kutta Anthony Iannetti Main CFD Forum 1 February 3, 2001 01:14
Diagonally Dominate Runge Kutta Method Anthony Iannetti Main CFD Forum 0 January 23, 2001 22:27
