Dynamic contact angle
Like Tree6Likes
Old   August 2, 2014, 05:38
Default Dynamic Contact Angle - algorithm
  #21
Anjishnu Choudhury
Anjishnu Choudhury is on a distinguished road
I am having a difficult time in finding the source files of algorithms involved in evaluating the dynamic contact angles. And when the angles are specified, how does it relate with the alpha-field?
Anjishnu Choudhury is offline   Reply With Quote
Old   August 5, 2014, 22:19
Christian Butcher
chrisb2244 is on a distinguished road
The sources for the alphaContactAngles can be found in
.../OpenFOAM-x.y.z/src/transportProperties/twoPhaseProperties/alphaContactAngle/
where x.y.z is your version number, and ... implies your installation path, probably /home or /home/username, I guess? In those cases, ~/OpenFOAM-2.y.z/rest/of/path should probably work.
You can use find . -iname *contactAngle* within the OpenFOAM source tree (.../src) to find these files, but probably it would work from any parent directory (I imagine there are not many other files on your system called *contactAngle*)
Anjishnu Choudhury likes this.
chrisb2244 is offline   Reply With Quote
Old   August 15, 2014, 17:02
Default Source code explanation
  #23
Anjishnu Choudhury
Hey,
I am confused with few terms like, Uwall(Up.patchInternalField() - Up). What does it physically mean?
How is the Uwall (or Up) evaluated (or taken input from user) ?
Thanks in advance!
Old   February 19, 2021, 08:27
rasoul
rasool_soofi is on a distinguished road
Originally Posted by Mahdi2010 View Post
Hi all
I am still trying to understand how ''dynamiccontactangle'' works in OpenFOAM.
Of course thetaA and thetaR are determined based on the material properties of the surface, but ''utheta'' is still the question. What does it mean exactly?
uTheta is a scaling factor with same dimensions as velocity (LT^-1). It affects the rate at which the contact angle changes when the capillary number changes. I usually run the model without contact angle definition and see what is the range of velocity near to the wall at the interface and based on that will choose an appropriate scaling factor, uTheta. Maybe the name "uTheta" is misleading because it's a velocity not an angle/angular velocity.
Dynamic Contact Angle Definition (dynamicAlphaContactAngle)
Good luck
rasool_soofi is offline   Reply With Quote
Old   June 14, 2021, 00:22
A. Min
alimea is on a distinguished road
Originally Posted by rasool_soofi View Post
Good luck
Hi guys
I have a question about uTheta.
Could you please give me an explanation about it? What is it?
I solved my case one time with uTheta = 2 and another time with uTheta = 0.01, and found that my case is very sensitive to the uTheta value. How can we select the best value for uTheta?
Thanks
alimea is offline   Reply With Quote
Moving contact line (dynamic contact angle) Pulli FLUENT 0 March 1, 2007 13:31
UDF for dynamic contact angle Aireen FLUENT 0 August 11, 2006 12:08
Dynamic contact angle Aireen FLUENT 1 August 10, 2006 17:01
Dynamic Contact Angle Maged Main CFD Forum 1 July 25, 2006 21:59
Dynamic contact angle Aireen FLUENT 2 July 5, 2006 14:14
