Control the running of program
Old   July 26, 2005, 20:36
Default I want to stop the program aft
liu
Xiaofeng Liu
liu is on a distinguished road
I want to stop the program after its running for a period of time, say 10 hours. Is there a method to let it stop "normally".
This question rises because the supercomputers in our university has a system which run jobs according to the time and processors demand. Some time my job is killed before it is finished because my time slot is used up and the worst thing is the results are not saved. What I want to do is to save the results and quit the program just before killing happends.
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   July 27, 2005, 06:19
Default 1) dump frequently enough. You
Mattijs Janssens
mattijs is on a distinguished road
1) dump frequently enough. You can specify to dump every so often. Check out the options on writeControl in the controlDict.
2) the new purgeWrite allows you to keep only say the last few dumps. So now you can dump very frequently and not fill up your disk.
3) if you are interested in stopping at exactly 10 hours you could try to use the foamEndJob script and schedule it to be started at exactly 10 hours. It will modify the controlDict to do a 'writeNow' end. I haven't looked at this script for a while so it might be out of date.
I think option 2 should be most effective.
mattijs is offline   Reply With Quote
Old   July 27, 2005, 07:01
Default You will of course need to est
Gavin Tabor
grtabor is on a distinguished road
You will of course need to estimate how long a time it will take to actually write the data to disk; otherwise you could find that the code is being killed halfway through the write operation.
Gavin
grtabor is offline   Reply With Quote
Timestep control via CEL? Claudia CFX 7 September 14, 2007 06:00
Solver Control Anantha CFX 1 September 4, 2007 14:30
Running in patch when your license is running out Andrew CFX 2 August 9, 2007 14:48
Diffusion control Julie Siemens 4 February 19, 2002 08:54
control plotting in fortran program zhe zhang Main CFD Forum 2 November 16, 1999 14:10
