Setting nodes value explicitly
Old   September 8, 2005, 05:37
Default Is there a way to set the valu
Maka Mohu
maka is on a distinguished road
Is there a way to set the value of internal nodes explicitly to certain value for all time?
The situation is as follows, I face a case where in small part of the domain, there are lots of protrusions of small size also. Presenting such small changes in geometry by different blocks is not convenient. On the other hand the local refinement that one gets from each block is not required, since this part of the domain is small and fine mesh can be used.
I have seen a message in the board about "timeVaryingUniformFixedValueFvPatchField" but I think this may not help since in my I case I need to set the value of indidual internal cell node(s) to zero without defining blocks for them for the above reasons.
Thanks.
maka is offline   Reply With Quote
how to solve a steady problem explicitly meda Main CFD Forum 6 September 25, 2008 07:53
Moving nodes jon CFX 5 October 4, 2006 18:35
how to get the velocity of nodes by UDF? tony FLUENT 3 November 26, 2005 07:03
about nodes Hannah liang CFX 3 July 25, 2002 02:35
Nodes positions + velocity and pressure values at the nodes Lily Kabanj FLUENT 1 March 13, 2000 20:21
