September 23, 2005, 11:39 |
Hi i'm trying to analize a nac
Muzio Grilli
Rep Power: 17 |
Hi i'm trying to analize a naca 0012 airfoil at mach
0.2 and 2000 meters altitude. I'm using TurbFoam solver and my process crashes everytime.I've set this boundary conditions velocity inlet pressure outlet airfoil (wall functions) top and bottom (slip) I've set a velocity value at the inlet and then the initial velocity field is set to zero. The pressure value is the same for the outlet and the initial field I've set a value for K and epsilon for the initial field and the velocity inlet |
September 23, 2005, 13:31 |
This you could investigate:
Mattijs Janssens
Rep Power: 26 |
Do you get a memory fault (sigsegv etc.) or floating point error (sigfpu). Is it diverging? Are you running with FOAM_ABORT / FOAM_SIGFPE (see board)? Is eps non-zero? Is there inflow at the outlet? |
September 26, 2005, 06:42 |
Setting the initial velocity f
Joao Henriques
Setting the initial velocity field to zero is not a good ideia because you introduce a discontinuity at the inlet that is physically irrealistic and the equations become more stiff when aproaching the zero velocity.
I sugest you initialize all the initial field equal to the inlet boundary conditions. |
September 26, 2005, 06:47 |
I solved this problem using so
Muzio Grilli
Rep Power: 17 |
I solved this problem using sonicTurbFoam solver,but now i have another problem:
I have a good velocity field but the pressure field is a bit strange. Someone can tell me if when i visualize p with paraview i'm visualizing dinamic pressure or static pressure? |
low rey Naca 0012 | Ravi | FLUENT | 5 | September 26, 2006 16:34 |
Naca 0012 | Raj | FLUENT | 2 | September 23, 2006 16:55 |
NACA 0012 | Ihab Sraj | CFX | 6 | August 29, 2006 11:35 |
Naca 0012 | Arsineh Orland | Main CFD Forum | 1 | January 19, 2003 17:52 |
flow over naca 0012 | Frederic Felten | Main CFD Forum | 6 | May 23, 2001 12:45 |
