Unsteady SIMPLE solver
Old   October 19, 2005, 11:06
Default I'm having a problem generatin
Håkan Nilsson
hani is on a distinguished road
I'm having a problem generating a solution with the turbFoam solver, and I have been recommended to write an unsteady SIMPLE solver. Has anyone done this already?
My problem with the turbFoam solver can be that there is a big difference in Courant numbers throughout the mesh. Did anyone have any experience on this?
I have tried two different quite different 3D cases with two different grids, for which I am able to get steady solutions using simpleFoam.
Håkan.
hani is offline   Reply With Quote
Old   October 25, 2005, 06:23
Default Where can I find information o
Håkan Nilsson
Where can I find information on the following:
(I have searched the forum and the manual, but I can of course have missed it)
What is the difference between
tmp<fvvectormatrix> UEqn; and
fvVectorMatrix UEqn;
The former occurs in simpleFoam and the latter occurs in turbFoam. In simpleFoam the UEqn is cleared after use (UEqn.clear();). Does this have anything to do with the difference? When running without the clear statement in simpleFoam I seem to run out of memory. Why is that not the case with fvVectorMatrix UEqn; in turbFoam?
What are A() and H() in simpleFoam and turbFoam?
Håkan.
Old   October 25, 2005, 12:17
Default Sorry, I see that some bracket
Håkan Nilsson
Sorry, I see that some brackets are missing in the distributed e-mail for some reason. The complete message is however available in the forum.
I guess that someone knows the answers?
Håkan.
Old   October 25, 2005, 14:43
Default tmp is just a container class
Mattijs Janssens
mattijs is on a distinguished road
tmp is just a container class to aid memory management for allocated objects.
mattijs is offline   Reply With Quote
Simple foam solver mardinoglu OpenFOAM Running, Solving & CFD 1 October 17, 2014 05:56
Simple 2d Matlab Solver Gabriel Usera Main CFD Forum 7 May 14, 2007 01:11
unsteady using SIMPLE algorithm simple Main CFD Forum 3 June 24, 2006 04:43
nUMECA UNSTEADY SOLVER dimitris Main CFD Forum 1 May 16, 2001 11:28
Does anyone work at SIMPLE in unsteady and compressibel flow Junl Main CFD Forum 1 February 4, 2000 22:24
