Problem with rotating impeller
Old   October 11, 2005, 12:45
Default hello, i need a help how can
Brahim Aakti
brahim is on a distinguished road
hello,
i need a help how can we use Openfoam for creating a rotating object onto an axis. for example, an impeller into a reactor in 3d.
thanks.
brahim is offline   Reply With Quote
Old   October 11, 2005, 16:16
Default If you have the CAD model, you
Billy
billy is on a distinguished road
If you have the CAD model, you can mesh it using a mesher and then import it into OpenFOAM. OpenFOAM can read several formats. Take a look at:
http://www.opencfd.co.uk/openfoam/doc/userse9.html
billy is offline   Reply With Quote
Old   October 12, 2005, 04:55
Default The mixer2D tutorial has slidi
Mattijs Janssens
mattijs is on a distinguished road
The mixer2D tutorial has sliding (rotating) meshes if that is what you want.
mattijs is offline   Reply With Quote
Old   October 12, 2005, 10:29
Default thank you , I looked at the ca
Brahim Aakti
thank you , I looked at the case of mixer2D but I wanted to make turn an impeller created by Gambit in 3d and I ask if possible to modify the code of mixer2D which is valid only for one grid 2d, and if you have some remarks!.
thanks again.
Old   October 26, 2005, 12:36
Default hello, I imported an object
Brahim Aakti
hello,
I imported an object extension .msh from gambit and I wanted to turn it by OpenFoam,and by using the sliding mesh to turn the object on an axis of rotation a problem occurred initially :FOAM FATAL ERROR : Not all zones and patches needed in the definition have been found. Please check your mesh definition.
after,i changed the notation and I used those of the code src/topoFvMesh/mixerFvMesh/mixerFvMesh.C and here the problem:
-> FOAM FATAL ERROR : Bad points.
From function void plane::calcPntAndVec
const point&,
const point&,
const point&
i thank you four helping me.
Old   October 26, 2005, 14:49
Default That error occurs because the
Eugene de Villiers
eugene is on a distinguished road
That error occurs because the code is trying to creat an illegal plane, i.e. all the points passed to the plane constructor lie in a straight line.
Not sure how or why this happens in mixerFvMesh.C
My guess is it is a tolerance issue.
The best way to fix it would be to check for this condition before constructing a plane (or building the check into the plane constructor) and having some exception handling. To find out were the problem is happening, you will have to compile the application with debug switches and do a core trace via gdb.
Keep us updated.
eugene is offline   Reply With Quote
Rotating impeller Pedro Lima CFX 15 January 27, 2012 06:33
Any body help me!, Impeller simulation problem. Desperado FLUENT 2 June 9, 2009 14:04
rotating bucket problem brown CFX 2 October 3, 2007 02:13
Boundries of rotating impeller created in Gambit ? Mounir FLUENT 2 October 23, 2000 07:56
BC's for a sliding grid problem: statorcentrifugal impeller Agostino De Marco FLUENT 0 March 4, 2000 08:52
