Setting a boundary conditions
Old   November 23, 2005, 12:21
Default Hi, I don't know the OpenFoam
mer
merrouche djemai
mer is on a distinguished road
I don't know the OpenFoam very well, but I ask on the strategy used to impose boundary conditions within the code.
If I generate my mesh with blockMesh utility and I have some boundary conditions to implement for my case, should I pass via the FoamX or I can try directly the boundary file? the problem here is with the number of patchs, when I start and when I stoped if I do it manually?
please tel me if i'm wrong in the way.
mer is offline   Reply With Quote
Old   November 24, 2005, 14:53
Default You can change the patch types
Mattijs Janssens
mattijs is on a distinguished road
You can change the patch types by hand (as long as they're consistent with the field types).
You cannot change the number of faces or starting face.
You can add/remove zero-sized patches to/from the end of the boundary list.
However unless you really know what you're doing better stick with FoamX.
mattijs is offline   Reply With Quote
setting boundary conditions on internal edges Renate Stump FLUENT 4 November 7, 2008 11:55
VOF and setting boundary conditions dave00001 FLUENT 0 January 25, 2008 13:37
Wall boundary conditions setting Andrea FLUENT 2 January 16, 2006 12:01
help setting up boundary conditions for combustor Tomas CFX 2 November 3, 2005 04:34
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
