Give me help Thanks
Old   November 15, 2005, 17:12
Default Dear All, I am a newer of
Guoxiang
liugx212 is on a distinguished road
Dear All,
I am a newer of the OpenFoam. I have a file of VTK which save the MESH of geomtry. I want to import this file to OpenFoam. But I do not know how to do? Could you please give some help for this matter?
Thanks deeply.
Guoxiang
liugx212 is offline   Reply With Quote
Old   November 16, 2005, 11:07
Default Hi Buoxiang, I'm not an exp
Maka Mohu
maka is on a distinguished road
Hi Buoxiang,
I'm not an expert but I think that you should make the message title more relevant to your question. For example, "importing VTK file to OpenFOAM". This will help people with experience spot and answer your message. Also it will help other people searching for some information using the search link, locate your question and its subsequent replies. Another advice is to search the forum for relevant messages of your topic before posting. You may use the link:
http://www.cfd-online.com/cgi-bin/Op...cus/search.cgi
Best of luck,
Maka
maka is offline   Reply With Quote
Old   November 16, 2005, 12:49
Default Hi Maka: Thanks for your he
Guoxiang
Hi Maka:
Thanks for your help. I will check as you said.
Guoxiang
Old   November 16, 2005, 15:53
Default Hi Maka, I still not find the
Guoxiang
Hi Maka,
I still not find the method how to import VTk file to OpenFoam to compute? Do you have any idea?
Thanks deeply,
Guoxiang
Old   November 17, 2005, 05:21
Default I found only the opposite, whi
Maka Mohu
I found only the opposite, which is foamToVTK
/OpenFOAM/OpenFOAM-1.2/applications/utilities/postProcessing/dataConversion/foam ToVTK
My advice was only related to your message title. I'm now stuck in a similar probelm of importing solution from a user defined file format (in-house code format) to foam to use it as intial condition. The problem of importing is not easy but what I found yet is that I have to use a utility setField in :
/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/setFields
an example of how to use is in the dam break case in the tutorial. But yet I did not figure out how modify the setFieldsDict to do what I want.
I do not know if I helped you by providing this info. Try to post in one of the previous message posted about VTK, may one of its users can answer you.
best of luck,
Maka
Old   November 17, 2005, 06:00
Default I don't know of any converter
Mattijs Janssens
mattijs is on a distinguished road
I don't know of any converter from vtk to Foam mesh format.
You could have a look at some of the other converters (gmshToFoam, netgenNeutralToFoam etc.) and modify the one that fits your problem best.
There is a description of the vtk file formats on the vtk site. The 'legacy' file format (the one that foamToVTK writes) is probably easiest to parse.
mattijs is offline   Reply With Quote
Old   November 17, 2005, 18:32
Default Dear All, I have still no
Guoxiang
Dear All,
I have still no idea. Could you please give me more guidance.
Thanks deeply.
Guoxiang
Old   November 25, 2005, 00:48
Default Dear users, how can I write t
langloi
Dear users,
how can I write this equation in O.Foam :
div(rho*vv)=-grad(p)+div(mu[grad(v)+ grad(v)t])+F
my probleme is in the transpose of grad(v) (grad(v)t), v is the velocity.
thanks
Old   November 25, 2005, 07:11
Default I think this is what you are l
Eugene de Villiers
eugene is on a distinguished road
I think this is what you are looking for
line 115
OpenFOAM-1.2.1/src/turbulenceModels/incompressible/kEpsilon/kEpsilon.C
line 132
OpenFOAM-1.2.1/src/turbulenceModels/compressible/kEpsilon/kEpsilon.C
eugene is offline   Reply With Quote
give help sihat FLUENT 0 November 22, 2006 21:21
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Anybody could give me some idea? zhihang FLUENT 2 February 7, 2004 16:26
please give a help zhujianguo Phoenics 0 July 18, 2003 05:36
Give me a second Selina Tracy Main CFD Forum 3 March 29, 2001 07:25
