November 27, 2005, 11:41 |
I have a couple of questions r
Siddhartha Jain
Rep Power: 17 |
I have a couple of questions regarding mixer2D. I performed a search but couldn't find the answers to my question.
What do baffleWall and outsideSlider refer too? Does insideSlider refer to the outer boundary of the mixer? Thanks in advance. |
November 27, 2005, 13:51 |
You should try using a post-pr
Hrvoje Jasak
Rep Power: 33 |
You should try using a post-processing tool and look at these pieces individually. In short:
- impellerWall is the rotating part, including the mixer blades - baffleWall is the outside surface of the mixer vessel The definition of the sliding interface mesh modifier requires two surfaces that slide across each other. This insideSlider the the outside surface of the rotating part and the outsideSlider is the internal surface or the stationary part. Both are used to define the sliding interface mesh modifier. Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Tee mixer | Kasper | Main CFD Forum | 1 | August 31, 2007 12:43 |
Mixer Boundary Conditions | shawn | OpenFOAM Running, Solving & CFD | 1 | January 23, 2007 04:07 |
air mixer in a furnace | Sam Salari | FLUENT | 0 | October 14, 2005 13:18 |
2D_Multiphase Mixer Tank | Hossein | FLUENT | 3 | January 8, 2005 01:12 |
static mixer | fish | FLUENT | 0 | January 5, 2005 12:19 |
