Total pressure boundary condition
Old   December 10, 2005, 14:41
Default Hi everybody!! I have to anal
Muzio Grilli
maritozzo is on a distinguished road
Hi everybody!!
I have to analyze the flow through an injector, i know there is not a solver for this kind of problem but first I wonna know if at least OpenFoam has the boundary conditions i need.
I decided to set the totalPressure boundary condition on the Inlet p0=p+(1/2)rho*U^2
so I specify in the pd file at time 0:
INLET
type totalPressure;
p0 uniform 12000000;
What do I have to specify in the U file
2nd question: as the time goes the velocity at the Inlet grows and consequently I should change the value of k and epsilon so i can't specify for them a fixed value but i thaught that the new k and the new epsilon should be calculated at each time step
3rd question: I decided to use K-epsilon turbulence model but at the beginning the fluid is still so intially the flow is laminar so do I have also to switch the turbulence model
Thanks
maritozzo is offline   Reply With Quote
Old   January 29, 2011, 13:53
Default the same question
Mohammad.R.Shetab
mrshb4 is on a distinguished road
Hi
I have the same question as your first one!!!
I think pressureInletVelocity can be used but I'm not sure about it.
Mohammadreza
mrshb4 is offline   Reply With Quote
Old   January 31, 2011, 04:03
Christian Lucas
Chris Lucas is on a distinguished road
for the velocity field, use the pressureInletVelocity at the inlet as stated above. For the turbulence field, you can use turbulentIntensityKineticEnergyInlet (k) and turbulentMixingLengthDissipationRateInlet (epsilon)
Regard,
Christian
Chris Lucas is offline   Reply With Quote
Pressure Boundary condition abishek FLUENT 1 July 28, 2008 09:14
Total pressure boundary condition maritozzo OpenFOAM Running, Solving & CFD 0 December 10, 2005 13:56
Total pressure boundary condition bartold OpenFOAM Pre-Processing 0 November 7, 2005 09:45
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 11:06
Pressure Boundary Condition chiseung FLUENT 1 June 19, 2001 22:05
