September 14, 2005, 09:19 |
1,what is the meaning of the "
1,what is the meaning of the "time step continuity errors "
2, why the openfoam solve the P equation for two times . time step continuity errors Mean and max Courant Numbers = 0.104862 1.499 BICCG: Solving for Ux, Initial residual = 0.126377, Final residual = 5.5659e-06, No Iterations 12 BICCG: Solving for Uy, Initial residual = 0.340201, Final residual = 6.705e-06, No Iterations 13 ICCG: Solving for p, Initial residual = 0.661742, Final residual = 8.73282e-07, No Iterations 67 time step continuity errors : sum local = 8.54754e-09, global = 1.00275e-18, cumulative = 9.91247e-19 ICCG: Solving for p, Initial residual = 0.527485, Final residual = 9.40264e-07, No Iterations 66 time step continuity errors : sum local = 1.06335e-08, global = -1.84043e-19, cumulative = 8.07204e-19 ExecutionTime = 0.11 s |
September 14, 2005, 09:25 |
2. because you have said so.
Niklas Nordin
Rep Power: 29 |
September 14, 2005, 16:28 |
I would also like to know abou
Amelia
Rep Power: 17 |
I would also like to know about the meaning of the continuity errors. Is it the same as the mass conservation error?
September 15, 2005, 11:11 |
1)
Have a look at continuity
Niklas Wikstrom
Rep Power: 17 |
1)
Have a look at continuityErrs.H ($FOAM_SRC/cfdTools/incompressible/continuityErrs.H) The implementation is rather instructive. 2) Look in the case file: system/fvSolution, where you define the number of PISO corrections. |
December 14, 2005, 17:40 |
Dear All,
I also encounter
Guoxiang
Rep Power: 17 |
Dear All,
I also encounter this question when I run icoFoam case with 92*92*32 mesh. my time step is 0.005. I am not sure how to solve this problem. Increase or decrease the PISO or others? Could you please give some advice? Thanks a lot, Guoxiang |
