Could anybody help me see this error and give help
Old   December 30, 2005, 03:59
Default Dear all, Here, I tried to
Guoxiang
liugx212 is on a distinguished road
Dear all,
Here, I tried to run the icoFoam case by set some different block and wall with the default example. But I saw some strange message when I run it. So anybody can help me? (especially the "nan")?
Thank you very much.
message as:
Exec : icoFoam . cavity_nu
Date : Dec 29 2005
Time : 12:24:27
Host : liu
PID : 5445
Root : /home/liu/OpenFOAM/liu-1.2/run/tutorials/icoFoam
Case : cavity_nu
Nprocs : 1
Create time
Create mesh for time = 0
Reading field nu
Reading field p
Reading field U
Starting time loop
Time = 0.0005
Mean and max Courant Numbers = 0 0.92
BICCG: Solving for Ux, Initial residual = 1, Final residual = 4.19266e-09, No Iterations 1
ICCG: Solving for p, Initial residual = 1, Final residual = 7.70284e-07, No Iterations 125
time step continuity errors : sum local = 3.85141e-09, global = 2.78955e-12, cumulative = 2.78955e-12
ICCG: Solving for p, Initial residual = 7.77916e-05, Final residual = 8.65143e-07, No Iterations 48
time step continuity errors : sum local = 8.02558e-09, global = 3.07845e-11, cumulative = 3.3574e-11
ExecutionTime = 40.69 s
Time = 0.001
Mean and max Courant Numbers = 9.206e-05 0.92
ICCG: Solving for p, Initial residual = 0.532929, Final residual = 8.62283e-07, No Iterations 122
time step continuity errors : sum local = 6.04773e-09, global = 2.37704e-12, cumulative = 3.59511e-11
ICCG: Solving for p, Initial residual = 0.000983102, Final residual = 8.34183e-07, No Iterations 97
time step continuity errors : sum local = 5.56623e-09, global = 8.88229e-12, cumulative = 4.48334e-11
ExecutionTime = 70.8 s
Time = 0.0015
Mean and max Courant Numbers = 8.30813e-05 0.92
ICCG: Solving for p, Initial residual = 0.274277, Final residual = 9.08443e-07, No Iterations 113
time step continuity errors : sum local = 7.75098e-09, global = -4.96195e-12, cumulative = 3.98714e-11
ICCG: Solving for p, Initial residual = 0.00152708, Final residual = 9.76734e-07, No Iterations 92
time step continuity errors : sum local = 1.19559e-08, global = -4.40766e-11, cumulative = -4.20515e-12
ExecutionTime = 99.68 s
Time = 0.002
Mean and max Courant Numbers = 7.65681e-05 0.92
ICCG: Solving for p, Initial residual = 0.133571, Final residual = 9.93934e-07, No Iterations 104
time step continuity errors : sum local = 1.38197e-08, global = -1.40739e-11, cumulative = -1.82791e-11
ICCG: Solving for p, Initial residual = 0.00206827, Final residual = 8.97272e-07, No Iterations 100
time step continuity errors : sum local = 1.47361e-08, global = 2.35944e-10, cumulative = 2.17665e-10
ExecutionTime = 128.16 s
Time = 0.0025
Mean and max Courant Numbers = 0.000142555 0.92
ICCG: Solving for p, Initial residual = 0.0909778, Final residual = 9.85564e-07, No Iterations 103
time step continuity errors : sum local = 1.76297e-08, global = 4.43202e-12, cumulative = 2.22097e-10
ICCG: Solving for p, Initial residual = 0.00284499, Final residual = 9.0875e-07, No Iterations 107
time step continuity errors : sum local = 1.8059e-08, global = -2.44552e-10, cumulative = -2.24546e-11
ExecutionTime = 157.69 s
Time = 0.003
Mean and max Courant Numbers = 0.000218516 0.92
ICCG: Solving for p, Initial residual = 0.0724909, Final residual = 9.1208e-07, No Iterations 106
time step continuity errors : sum local = 1.93639e-08, global = -2.23886e-11, cumulative = -4.48431e-11
ICCG: Solving for p, Initial residual = 0.00436903, Final residual = 9.98486e-07, No Iterations 110
time step continuity errors : sum local = 2.2926e-08, global = -2.88351e-10, cumulative = -3.33194e-10
ExecutionTime = 187.94 s
Time = 0.0035
Mean and max Courant Numbers = 0.000302188 0.92
ICCG: Solving for p, Initial residual = 0.0617661, Final residual = 8.63318e-07, No Iterations 106
time step continuity errors : sum local = 2.08507e-08, global = -3.61446e-11, cumulative = -3.69339e-10
ICCG: Solving for p, Initial residual = 0.00648291, Final residual = 7.96502e-07, No Iterations 113
time step continuity errors : sum local = 2.04635e-08, global = -1.65836e-12, cumulative = -3.70997e-10
ExecutionTime = 218.61 s
Time = 0.004
Mean and max Courant Numbers = 0.000392286 0.94926
ICCG: Solving for p, Initial residual = 0.056025, Final residual = 9.97256e-07, No Iterations 111
time step continuity errors : sum local = 2.67473e-08, global = -4.71886e-11, cumulative = -4.18185e-10
ICCG: Solving for p, Initial residual = 0.00919233, Final residual = 8.93183e-07, No Iterations 114
time step continuity errors : sum local = 2.52406e-08, global = -1.03814e-10, cumulative = -5.21999e-10
ExecutionTime = 249.87 s
Time = 0.0045
Mean and max Courant Numbers = 0.000518264 0.956784
ICCG: Solving for p, Initial residual = 0.0535665, Final residual = 8.53037e-07, No Iterations 114
time step continuity errors : sum local = 2.48831e-08, global = 8.51923e-11, cumulative = -4.36807e-10
ICCG: Solving for p, Initial residual = 0.0105582, Final residual = 8.92687e-07, No Iterations 115
time step continuity errors : sum local = 2.72616e-08, global = -1.07744e-10, cumulative = -5.44551e-10
ExecutionTime = 281.66 s
Time = 0.005
Mean and max Courant Numbers = 0.000762297 1.22303
ICCG: Solving for p, Initial residual = 0.0518001, Final residual = 8.95838e-07, No Iterations 114
time step continuity errors : sum local = 2.81695e-08, global = 7.61893e-11, cumulative = -4.68361e-10
ICCG: Solving for p, Initial residual = 0.013001, Final residual = 8.70653e-07, No Iterations 116
time step continuity errors : sum local = 2.85753e-08, global = 8.39893e-11, cumulative = -3.84372e-10
ExecutionTime = 313.38 s
Time = 0.0055
Mean and max Courant Numbers = 0.00108531 1.42547
ICCG: Solving for p, Initial residual = 0.0566779, Final residual = 9.75777e-07, No Iterations 115
time step continuity errors : sum local = 3.28695e-08, global = 1.61716e-10, cumulative = -2.22657e-10
ICCG: Solving for p, Initial residual = 0.020607, Final residual = 9.98442e-07, No Iterations 116
time step continuity errors : sum local = 3.5058e-08, global = 9.25758e-11, cumulative = -1.30081e-10
ExecutionTime = 345.66 s
Time = 0.006
Mean and max Courant Numbers = 0.00146893 1.4512
ICCG: Solving for p, Initial residual = 0.0665465, Final residual = 8.60932e-07, No Iterations 116
time step continuity errors : sum local = 3.08816e-08, global = 5.93393e-11, cumulative = -7.07414e-11
ICCG: Solving for p, Initial residual = 0.0268022, Final residual = 9.53653e-07, No Iterations 115
time step continuity errors : sum local = 3.57017e-08, global = -5.98839e-11, cumulative = -1.30625e-10
ExecutionTime = 378.12 s
Time = 0.0065
Mean and max Courant Numbers = 0.00197626 1.33144
ICCG: Solving for p, Initial residual = 0.0878394, Final residual = 9.16297e-07, No Iterations 115
time step continuity errors : sum local = 3.51914e-08, global = 1.79437e-10, cumulative = 4.88113e-11
ICCG: Solving for p, Initial residual = 0.0328187, Final residual = 9.90477e-07, No Iterations 81
time step continuity errors : sum local = 4.00977e-08, global = 2.32018e-10, cumulative = 2.80829e-10
ExecutionTime = 406.46 s
Time = 0.007
Mean and max Courant Numbers = 0.00269024 1.65574
ICCG: Solving for p, Initial residual = 0.119433, Final residual = 9.52277e-07, No Iterations 118
time step continuity errors : sum local = 3.96885e-08, global = 2.58568e-10, cumulative = 5.39397e-10
ICCG: Solving for p, Initial residual = 0.0496735, Final residual = 9.95551e-07, No Iterations 119
time step continuity errors : sum local = 4.18401e-08, global = -2.42567e-10, cumulative = 2.9683e-10
ExecutionTime = 439.43 s
Time = 0.0075
Mean and max Courant Numbers = 0.00307952 1.79024
ICCG: Solving for p, Initial residual = 0.107969, Final residual = 9.8169e-07, No Iterations 119
time step continuity errors : sum local = 4.39189e-08, global = 2.41551e-10, cumulative = 5.38381e-10
ICCG: Solving for p, Initial residual = 0.0857869, Final residual = 9.39086e-07, No Iterations 102
time step continuity errors : sum local = 4.18273e-08, global = 6.52387e-11, cumulative = 6.0362e-10
ExecutionTime = 470.56 s
Time = 0.008
Mean and max Courant Numbers = 0.00436275 3.38395
ICCG: Solving for p, Initial residual = 0.18536, Final residual = 9.56177e-07, No Iterations 121
time step continuity errors : sum local = 4.74762e-08, global = 5.2253e-10, cumulative = 1.12615e-09
ICCG: Solving for p, Initial residual = 0.22345, Final residual = 9.79652e-07, No Iterations 118
time step continuity errors : sum local = 5.38037e-08, global = -4.86133e-10, cumulative = 6.40018e-10
ExecutionTime = 503.57 s
Time = 0.0085
Mean and max Courant Numbers = 0.00938964 12.6062
ICCG: Solving for p, Initial residual = 0.533673, Final residual = 9.74575e-07, No Iterations 139
time step continuity errors : sum local = 8.98897e-08, global = 1.3494e-09, cumulative = 1.98942e-09
ICCG: Solving for p, Initial residual = 0.493049, Final residual = 9.34648e-07, No Iterations 138
time step continuity errors : sum local = 3.43542e-07, global = -6.03444e-09, cumulative = -4.04501e-09
ExecutionTime = 540.97 s
Time = 0.009
Mean and max Courant Numbers = 0.172909 197.452
ICCG: Solving for p, Initial residual = 0.981106, Final residual = 8.97684e-07, No Iterations 138
time step continuity errors : sum local = 1.14836e-05, global = 2.58977e-07, cumulative = 2.54932e-07
ICCG: Solving for p, Initial residual = 0.944272, Final residual = 9.85265e-07, No Iterations 138
time step continuity errors : sum local = 0.000392127, global = -9.60225e-06, cumulative = -9.34731e-06
ExecutionTime = 578.42 s
Time = 0.0095
Mean and max Courant Numbers = 257.545 400394
ICCG: Solving for p, Initial residual = 0.999997, Final residual = 9.56969e-07, No Iterations 150
time step continuity errors : sum local = 70.4322, global = -0.457655, cumulative = -0.457664
ICCG: Solving for p, Initial residual = 0.999997, Final residual = 8.11788e-07, No Iterations 144
time step continuity errors : sum local = 1.15845e+07, global = -152185, cumulative = -152185
ExecutionTime = 617.78 s
Time = 0.01
Mean and max Courant Numbers = 6.36749e+12 1.48312e+16
ICCG: Solving for p, Initial residual = 1, Final residual = 2.24066, No Iterations 5001
time step continuity errors : sum local = 1.98651e+23, global = 1.33832e+18, cumulative = 1.33832e+18
ICCG: Solving for p, Initial residual = 1, Final residual = 20.1767, No Iterations 5001
time step continuity errors : sum local = 3.44205e+33, global = -3.28773e+27, cumulative = -3.28773e+27
ExecutionTime = 1735.05 s
Time = 0.0105
Mean and max Courant Numbers = 2.82878e+33 1.54814e+37
ICCG: Solving for p, Initial residual = 1, Final residual = 1641.81, No Iterations 5001
time step continuity errors : sum local = 2.05274e+40, global = -5.65532e+34, cumulative = -5.65532e+34
ICCG: Solving for p, Initial residual = 0.000194636, Final residual = 2.28396, No Iterations 5001
time step continuity errors : sum local = 7.88062e+45, global = -1.45249e+42, cumulative = -1.45249e+42
ExecutionTime = 2865.59 s
Time = 0.011
Mean and max Courant Numbers = 6.20707e+45 1.23315e+50
BICCG: Solving for Ux, Initial residual = 0.974883, Final residual = 87.4909, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 0.910636, Final residual = 0.915621, No Iterations 1001
BICCG: Solving for Uz, Initial residual = 0.829574, Final residual = 0.829772, No Iterations 1001
ICCG: Solving for p, Initial residual = 1, Final residual = 120.812, No Iterations 5001
time step continuity errors : sum local = 4.2199e+57, global = 5.62346e+53, cumulative = 5.62346e+53
ICCG: Solving for p, Initial residual = 0.974889, Final residual = 41.6035, No Iterations 5001
time step continuity errors : sum local = 1.07461e+61, global = 6.42855e+57, cumulative = 6.42912e+57
ExecutionTime = 4904.79 s
Time = 0.0115
Mean and max Courant Numbers = 8.47534e+60 9.2728e+64
BICCG: Solving for Ux, Initial residual = 0.999957, Final residual = 1.00236, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 0.999979, Final residual = 1.61928, No Iterations 1001
BICCG: Solving for Uz, Initial residual = 0.999937, Final residual = 1.01002, No Iterations 1001
ICCG: Solving for p, Initial residual = 1, Final residual = 34.8251, No Iterations 5001
time step continuity errors : sum local = 1.44208e+68, global = -8.09518e+63, cumulative = -8.09518e+63
ICCG: Solving for p, Initial residual = 0.676704, Final residual = 6.75887, No Iterations 5001
time step continuity errors : sum local = 2.28907e+71, global = -6.17318e+66, cumulative = -6.18128e+66
ExecutionTime = 6947.87 s
Time = 0.012
Mean and max Courant Numbers = 1.75251e+71 3.21056e+75
BICCG: Solving for Ux, Initial residual = 0.99995, Final residual = 14.4124, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 0.999987, Final residual = 1.00019, No Iterations 1001
BICCG: Solving for Uz, Initial residual = 0.999995, Final residual = 8.3139, No Iterations 1001
ICCG: Solving for p, Initial residual = 1, Final residual = 983.029, No Iterations 5001
time step continuity errors : sum local = 1.72675e+82, global = 8.55375e+79, cumulative = 8.55375e+79
ICCG: Solving for p, Initial residual = 0.971493, Final residual = 476.704, No Iterations 5001
time step continuity errors : sum local = 7.31244e+86, global = 2.3521e+83, cumulative = 2.35296e+83
ExecutionTime = 8985.8 s
Time = 0.0125
Mean and max Courant Numbers = 6.34151e+86 1.16279e+91
BICCG: Solving for Ux, Initial residual = 0.999929, Final residual = 0.999929, No Iterations 1001
BICCG: Solving for Uy, Initial residual = 0.999979, Final residual = 0.999979, No Iterations 1001
BICCG: Solving for Uz, Initial residual = 0.999989, Final residual = 0.999989, No Iterations 1001
ICCG: Solving for p, Initial residual = 1, Final residual = 2561.44, No Iterations 5001
time step continuity errors : sum local = 4.65208e+93, global = -2.2301e+89, cumulative = -2.2301e+89
ICCG: Solving for p, Initial residual = 0.23393, Final residual = 31.0314, No Iterations 5001
time step continuity errors : sum local = 4.17777e+97, global = -6.10628e+93, cumulative = -6.1065e+93
ExecutionTime = 11024.1 s
Time = 0.013
Mean and max Courant Numbers = 3.2115e+97 1.42409e+102
BICCG: Solving for Ux: solution singularity
BICCG: Solving for Uy: solution singularity
BICCG: Solving for Uz: solution singularity
ICCG: Solving for p: solution singularity
time step continuity errors : sum local = 5.91012e+100, global = -4.34667e+98, cumulative = -4.34673e+98
time step continuity errors : sum local = 1.32585e+103, global = -2.42172e+100, cumulative = -2.46519e+100
ExecutionTime = 11050.5 s
Time = 0.0135
Mean and max Courant Numbers = 4.40402e+102 2.27099e+107
time step continuity errors : sum local = 1.07773e+105, global = -6.32456e+101, cumulative = -6.57107e+101
time step continuity errors : sum local = 2.2921e+106, global = 2.09218e+102, cumulative = 1.43507e+102
ExecutionTime = 11076.9 s
Time = 0.014
Mean and max Courant Numbers = 8.07859e+105 7.97372e+110
time step continuity errors : sum local = 2.67323e+107, global = -1.50222e+103, cumulative = -1.35871e+103
time step continuity errors : sum local = 6.46538e+108, global = 7.82788e+103, cumulative = 6.46917e+103
ExecutionTime = 11103.2 s
Time = 0.0145
Mean and max Courant Numbers = 2.82932e+108 1.28034e+113
time step continuity errors : sum local = 4.59533e+109, global = 1.57339e+107, cumulative = 1.57404e+107
time step continuity errors : sum local = 2.76356e+112, global = 2.01057e+107, cumulative = 3.5846e+107
ExecutionTime = 11129.7 s
Time = 0.015
Mean and max Courant Numbers = 1.29641e+112 1.37595e+117
time step continuity errors : sum local = 2.3866e+113, global = -7.29266e+108, cumulative = -6.9342e+108
time step continuity errors : sum local = 1.03505e+117, global = 4.29708e+109, cumulative = 3.60366e+109
ExecutionTime = 11156.1 s
Time = 0.0155
Mean and max Courant Numbers = 4.07057e+116 4.80308e+121
time step continuity errors : sum local = 7.28929e+117, global = -4.83362e+112, cumulative = -4.83001e+112
time step continuity errors : sum local = 5.34392e+120, global = 3.64103e+112, cumulative = -1.18898e+112
ExecutionTime = 11182.5 s
Time = 0.016
Mean and max Courant Numbers = 2.50969e+120 2.10875e+125
time step continuity errors : sum local = 3.70685e+121, global = -5.24002e+115, cumulative = -5.24121e+115
time step continuity errors : sum local = 7.40905e+124, global = 3.22655e+117, cumulative = 3.17414e+117
ExecutionTime = 11208.8 s
Time = 0.0165
Mean and max Courant Numbers = 3.20916e+124 3.03689e+129
time step continuity errors : sum local = 5.53723e+125, global = -5.84876e+119, cumulative = -5.81702e+119
time step continuity errors : sum local = 1.91706e+129, global = 5.59198e+121, cumulative = 5.53381e+121
ExecutionTime = 11235.2 s
Time = 0.017
Mean and max Courant Numbers = 7.21336e+128 1.37116e+134
time step continuity errors : sum local = 1.40417e+130, global = -1.70218e+124, cumulative = -1.69664e+124
time step continuity errors : sum local = 1.6804e+135, global = 1.17533e+125, cumulative = 1.00567e+125
ExecutionTime = 11261.5 s
Time = 0.0175
Mean and max Courant Numbers = 6.93742e+134 1.24497e+140
time step continuity errors : sum local = 1.88834e+136, global = -3.47158e+127, cumulative = -3.46152e+127
time step continuity errors : sum local = 1.86505e+142, global = -4.73835e+129, cumulative = -4.77297e+129
ExecutionTime = 11287.9 s
Time = 0.018
Mean and max Courant Numbers = 6.60202e+141 1.24774e+147
time step continuity errors : sum local = 9.19055e+142, global = -2.95232e+131, cumulative = -3.00005e+131
time step continuity errors : sum local = 9.61981e+148, global = -6.03847e+133, cumulative = -6.06847e+133
ExecutionTime = 11314.2 s
Time = 0.0185
Mean and max Courant Numbers = 3.39544e+148 4.24796e+153
time step continuity errors : sum local = nan, global = nan, cumulative = nan
ExecutionTime = 11336.3 s
Time = 0.019
Mean and max Courant Numbers = nan 3.37293e+156
ExecutionTime = 11352.4 s
Time = 0.0195
Mean and max Courant Numbers = nan inf
ExecutionTime = 11368.6 s
Time = 0.02
ExecutionTime = 11385.5 s
Time = 0.0205
ExecutionTime = 11404.1 s
Time = 0.021
ExecutionTime = 11427.6 s
Time = 0.0215
ExecutionTime = 11461.6 s
Time = 0.022
ExecutionTime = 11515.3 s
Time = 0.0225
ExecutionTime = 11596.1 s
Time = 0.023
ExecutionTime = 11702.6 s
Time = 0.0235
ExecutionTime = 11824.7 s
Time = 0.024
ExecutionTime = 11952 s
Time = 0.0245
Mean and max Courant Numbers = nan nan
ExecutionTime = 12081.1 s
Time = 0.025
ExecutionTime = 12259.4 s
Time = 0.0255
ExecutionTime = 12448 s
Time = 0.026
ExecutionTime = 12630.1 s
Time = 0.0265
ExecutionTime = 12824 s
Time = 0.027
ExecutionTime = 13029 s
Time = 0.0275
ExecutionTime = 13236.8 s
Time = 0.028
ExecutionTime = 13443.4 s
Time = 0.0285
ExecutionTime = 13649.7 s
Time = 0.029
ExecutionTime = 13856.3 s
Time = 0.0295
ExecutionTime = 14062.6 s
Time = 0.03
ExecutionTime = 14270.2 s
Time = 0.0305
ExecutionTime = 14478.9 s
Time = 0.031
ExecutionTime = 14685.5 s
Time = 0.0315
ExecutionTime = 14895.1 s
Time = 0.032
ExecutionTime = 15103.4 s
Time = 0.0325
ExecutionTime = 15309.7 s
Time = 0.033
ExecutionTime = 15516 s
Time = 0.0335
ExecutionTime = 15722.4 s
Time = 0.034
ExecutionTime = 15928.4 s
Time = 0.0345
ExecutionTime = 16134.4 s
Time = 0.035
ExecutionTime = 16341.1 s
Time = 0.0355
ExecutionTime = 16550.5 s
Time = 0.036
ExecutionTime = 16758.1 s
Time = 0.0365
ExecutionTime = 16964.3 s
Time = 0.037
ExecutionTime = 17172.4 s
Time = 0.0375
ExecutionTime = 17378.7 s
Time = 0.038
ExecutionTime = 17585 s
Time = 0.0385
ExecutionTime = 17791.4 s
Time = 0.039
ExecutionTime = 17998 s
Time = 0.0395
ExecutionTime = 18205.1 s
Time = 0.04
ExecutionTime = 18412 s
Time = 0.0405
ExecutionTime = 18620 s
Time = 0.041
ExecutionTime = 18826 s
Time = 0.0415
ExecutionTime = 19032.6 s
Time = 0.042
ExecutionTime = 19241.8 s
Time = 0.0425
ExecutionTime = 19451.6 s
Time = 0.043
ExecutionTime = 19659.9 s
Time = 0.0435
ExecutionTime = 19867.9 s
Time = 0.044
ExecutionTime = 20076.4 s
Time = 0.0445
ExecutionTime = 20284.6 s
Time = 0.045
ExecutionTime = 20494 s
Time = 0.0455
ExecutionTime = 20702.1 s
Time = 0.046
ExecutionTime = 20912.5 s
liugx212 is offline   Reply With Quote
Old   January 4, 2006, 04:00
Default Hi. There are many things tha
Charles Ju
ploceus is on a distinguished road
Hi.
There are many things that can go wrong.
You have to play with it until you get it.
Try reducing time step. You have 0.0005 which may be too large. try 0.0001 or 0.0000001 or anywhere in between.
Is the value of nu correct in transportProperties?
If the run still diverges, something is wrong with your boundary conditions.
Hope this helps.
ploceus is offline   Reply With Quote
Old   January 4, 2006, 05:46
Default Dear Guoxiang, your solutio
VVqf
vvqf is on a distinguished road
Dear Guoxiang,
your solution does not converge.
nan = not a number (too huge number)
take Charles's suggestions.
first check your transportProperties and boundary conditions.
PS:
pls. make your title clear and specific so as to get better help. it does good to both you and the others.
vvqf is offline   Reply With Quote
Old   January 4, 2006, 19:07
Default Dear friends, Thanks for yo
Guoxiang
Dear friends,
Thanks for your help. You are right. I have tried to reduce the time step though it is too slow to compute.
Here, I tried nu as the field in createFields file. And I also set the air as 1.45e-5 and building as 1.45e+50. But it is still problem as above. So could you please give more details.
Thanks deeply.
Xiang
give help sihat FLUENT 0 November 22, 2006 21:21
Give me help Thanks liugx212 OpenFOAM Running, Solving & CFD 8 November 25, 2005 07:11
Could someone please give advice? Frank Wedburn Main CFD Forum 11 September 26, 2005 14:31
please give a help zhujianguo Phoenics 0 July 18, 2003 05:36
Give me a second Selina Tracy Main CFD Forum 3 March 29, 2001 07:25
