Questions about the inletOutlet and outletInlet boundary conditions
Like Tree134Likes
Old   August 9, 2017, 07:58
Default Pressure inlet Boundary condition in SIMPLE algorithm
  #21
abbas
ABS_abbas is on a distinguished road
Hi everyone,
I simulate a transient and in-compressible flow inside a PEM fuel cell and I don't know, how to enforce the " PRESSURE INLET " boundary condition?
my domain is a rectangular channel that fluid flows into the channel.
my domain is like a lid driven cavity. my inlet pressure is known but my velocity inlet (u_in) is unknown. other boundary is wall.
my domain have just one inlet boundary and 3 wall boundary. with no outlet boundary.
fluid(fuel) comes into channel and it is consumed(we have a sink inside channel that consume the fuel that comes to channel).there isn't any outlet.
I should set P_in=1 atm in inlet, but I heard that in SIMPLE we don't have absolute pressure.
what should I do?
ABS_abbas is offline   Reply With Quote
Old   August 10, 2017, 02:45
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Pressure driven flows are problematic. If you simply set a pressure difference this stay forever and drives the flow more and more until the system explodes. In reality, there is a balance between pressure difference and pressure resistance at a special flow.
I would start with velocity driven flow, set the pressure at the outflow to zero and change the inlet velocity until the measured / calculated pressure there is in the near of your known value.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 10, 2017, 12:07
sheaker's Avatar
Oskar
sheaker is on a distinguished road
I think I succeed in pressure driven flow. Check this boundary condition.
For p:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 101320;
boundaryField
    inlet
        type            totalPressure;
        p0              uniform 101325;
        U               U;
        phi             phi;
        rho             none;
        psi             none;
        gamma           1;
        value           uniform 101325;
    outlet
        type            fixedValue;
        value           uniform 101320;
    wall
        type            zeroGradient;
    defaultFaces
    type        empty;
For U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            pressureInletVelocity;
        value           uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    wall
        type            fixedValue;
    defaultFaces
    type        empty;
Let me know if it works for You, please.
Have a nice day.
Sheaker
sheaker is offline   Reply With Quote
Old   August 11, 2017, 07:47
Default inlet pressure boundary
  #24
abbas
thank you Mr. Pilz. but I think you didn't understand my problem.my case doesn't have outlet boundary. just one inlet and other boundaries are wall.
so I can't have an outlet boundary. I have to set pressure inlet in Inlet of domain.
information of my simulation:
transient, flow is in-compressible, using finite volume (SIMPLE algorithm), with Collocated grid.
I heard that in in-compressible flow, I have to set the pressure of a point to zero as a reference pressure point. is it correct?
Old   March 2, 2021, 02:16
Tushar Survase
ttsurvase is on a distinguished road
I am replying to your first query, inletOutlet Boundary condition is employed when user is not sure of flow direction. In inletOutlet BC, two boundary conditions are used. 1.zero Gradient, if flow is going out of domain. 2. fixedValue Bc, if flow is reversing. To accomodate both. I will explain the use using following example:
U: outlet { type inletOutlet; inletValue uniform (-2 0 0); value (0 0 0); }
So in the case, inletValue uniform (-2 0 0) is used for flow reversal phenomenon. While, if flow is going out, value 0 tells solver to use zeroGradient BC.
For more information, I will share the link of tutorial:
https://www.cfd.at/sites/default/fil...le%20Eight.pdf
Mahmoud Abbaszadeh and hr_nt like this.
ttsurvase is offline   Reply With Quote
Inletoutlet rengu OpenFOAM Running, Solving & CFD 8 December 25, 2015 16:44
Burgerbs equation non constant Boundary Conditions Initial Conditions arkangel OpenFOAM Running, Solving & CFD 1 October 2, 2008 15:48
questions in initial conditions and inlet boundary nick CFX 2 April 19, 2008 10:26
TwoPhaseEulerFoam and InletOutlet boundary condition hemph OpenFOAM Running, Solving & CFD 10 January 29, 2007 10:47
Integral boundary conditions turbulent intensitylength boundary conditions olesen OpenFOAM Running, Solving & CFD 0 July 27, 2006 08:18
