February 6, 2006, 11:45 |
Hello
When I run my case with
Aurelia Cure
Rep Power: 17 |
Hello
When I run my case with interFoam, I have the following: --> FOAM FATAL ERROR : incompatible dimensions for operation [pcorr[-1 3 -1 0 0 0 0] ] == [div(phi)[0 0 -1 0 0 0 0] ] From function checkMethod(const fvMatrix<type>&, const GeometricField<type,fvpatchfield,>&) in file /home/dm2/henry/OpenFOAM/OpemFOAM-1.2/src/OpenFOAM/lnInclude/fvMatrix.C at line 935. FOAM aborting the damBreak case works fine does someone know what I did wrong? Thanks Aurelia |
February 6, 2006, 11:54 |
Best guess is one of your init
Eugene de Villiers
Rep Power: 21 |
Best guess is one of your initial field dimensions is incorrected (usually pressure or dynamic viscosity). Compare with the interFoam sets.
February 6, 2006, 12:06 |
yes, it was the pressure
than
Aurelia Cure
Rep Power: 17 |
thank you Eugene Aurelia |
Incompatible fields for operation | tehache | OpenFOAM Running, Solving & CFD | 5 | January 30, 2018 16:32 |
Incompatible fields for operation | su_junwei | OpenFOAM Pre-Processing | 1 | October 15, 2008 09:34 |
Incompatible elements | coastal593 | OpenFOAM Running, Solving & CFD | 0 | March 26, 2008 15:34 |
The incompatible of UDF | Summer | FLUENT | 3 | April 23, 2007 05:11 |
