Estimation of the flow coefficient of an intake valve
Old   February 4, 2006, 09:57
Default Hi All, I'm asking for some
Tommaso Lucchini
lucchini is on a distinguished road
Hi All,
I'm asking for some advices about a CFD calculation I would like to perform. I need to calculate the flow coefficients of the intake valve of a pent-roof spark-ignition engine.
I created the mesh with commercial mesh generator and I converted it correctly. I defined three patches:
- walls: they are the cylinder walls, the port walls, the valve walls
- inlet: where the air comes in
- outlet: where the air goes out
Questions:
1) Which solver can I use? I was thinking about sonicTurbFoam. But I am not sure it can be the right choiche because the pressure difference experimentally imposed is usually about 0.1 bar. May I consider the fluid as incompressible?
2) If I use a sonicTurbFoam, what boundary conditions should I impose for pressure and velocity at inlet and outlet patches?
I was thinking:
inlet: fixedValue for velocity and zeroGradient for pressure
outlet: zeroGradient for velocity and fixedValue for pressure (set to the experimental value of 0.9 bar).
with this setup I get oscillations in the pressure field and I don't reach a steady solution as I would.
How can I get rid of these oscillations? Should I use pressureTransmissive instead for the pressure boundary condition for the outlet?
I really appreciate any suggestion/comments and would like to know if someone else foam-user has experiences about flow-coefficients estimation for engine valves.
Thanks a lot.
Regards.
Tommaso
lucchini is offline   Reply With Quote
Old   February 5, 2006, 06:37
Default grazie tommaso..
fedegavo
grazie tommaso..
Old   February 6, 2006, 07:46
Default Unless your flow is transonic,
Eugene de Villiers
eugene is on a distinguished road
Unless your flow is transonic, I would use rhoTurbFoam. And yes, a pressureTransmissive outlet is necessary to prevent wave reflection. (Please let me know how it [pressureTransmissive] performs, the last time I tried to use it I ran into some problems, which I didnt have time to investigate.)
eugene is offline   Reply With Quote
Old   February 7, 2006, 11:11
Default Ah finally Tommaso I can help
Fabian Peng Karrholm
fabianpk is on a distinguished road
Ah finally Tommaso I can help you!
I use the pressureTransmissive alot, it's very efficient at damping out oscillating waves in a wedge, especially if there's a very big pressure wave coming from a small nozzle into the wedge.
Nevertheless, remember to that lInf is a compromise between how reflective you can allow it to be and how important it is for the pressure to remain at pInf. A little trial and error is appropriate I think.
BTW How high is your estimated Mach number?
/Fabian
fabianpk is offline   Reply With Quote
Regarding Coefficient-of-Discharge of intake port LeelaPrasad Siemens 2 March 9, 2017 06:48
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
Flow measurement around intake valve pressure condition problem fedegavo OpenFOAM Running, Solving & CFD 1 January 20, 2006 14:06
incompressible air flow in air intake system reza besharati Main CFD Forum 4 June 4, 2001 21:23
Intake valve calculation khalel Main CFD Forum 1 May 3, 1999 11:47
