March 27, 2012, 06:30 |
#61 |
Rep Power: 16 |
Hi David,
thanks a lot! are you using as well same BC. because I have problem to implement them.. thanks Recep |
March 28, 2012, 02:11 |
#62 |
David Schellander
Rep Power: 16 |
yes I'm working on a small project for a course at university and have implemented the J&J boundary conditions based on the ideas of alberto passalacqua's work. regards, David |
March 28, 2012, 05:37 |
#63 |
Rep Power: 16 |
Hi David,
I am using OF210 and I was trying to implement J&J BC in tutorial case (bad2) and I got errors like in post 31.. can you help me? thanks, recep |
March 28, 2012, 05:49 |
#64 |
David Schellander
Rep Power: 16 |
I've read the problem and think that if I could have a look at your solver it could be possible that I can help. kind regards, David |
March 28, 2012, 05:55 |
#65 |
Rep Power: 16 |
thanks a lot...
could you give me your email address? I can send the solver to you... Best! |
December 7, 2012, 09:50 |
#66 |
Rep Power: 14 |
Dear Kanarya,
I have the same problem like mentioned in posts 31 and 63. I use compressibleTwoPhaseEulerFoam, OpenFoam version 2.1.x from 28.08.2012 The error message is: Reading transportProperties --> FOAM FATAL ERROR: request for dictionary kineticTheoryProperties from objectRegistry region0 failed available objects of type dictionary are 4 ( fvSchemes fvSolution data transportProperties ) What can I do? Regards, Stern |
December 8, 2012, 06:16 |
#67 | |
Rep Power: 16 |
I am not using OP anymore...I could not find out why it gives me error as well. The reason must be, code is done for old version and not suit for 21x. What is your project about? If you find the solution, I am also curious about it. sorry that I can not help you! Best! Kanarya |
heat transfer, new bc |
Boundary condition for UDS | Tomik | FLUENT | 0 | December 5, 2006 18:37 |
Boundary condition of the third kind or Danckwertz boundary condition | plage | OpenFOAM Running, Solving & CFD | 4 | October 3, 2006 13:21 |
Slip Boundary Condition for Moving Boundary | Shukla | Main CFD Forum | 3 | November 11, 2005 16:02 |
UDF boundary condition | Jeff | FLUENT | 2 | November 20, 2003 18:15 |
Boundary Condition in LES | Zhang Tsiang | Main CFD Forum | 3 | February 5, 2002 21:15 |
