New boundary condition
Like Tree2Likes
Old   April 14, 2009, 07:03
tnk
L.E.Tonkov
tnk is on a distinguished road
Thank you, Alexander for fast reply. As far as I understand inletOutlet, b.c. depend on U vector direction but not magnitude.
I send forum private message to you.
Best regards
Leonid
tnk is offline   Reply With Quote
Old   June 8, 2009, 22:19
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Can I ask in " valueFraction*U + (1-valueFraction)*dU = 0 ", dU means the normal gradient of U, i.e. dU/dn, or just the difference between internalField velocity and boundary velocity?
Bin
Originally Posted by niklas View Post
Hola,
Not 100 percent sure, but I'd say its like this:
N
zhoubinwx is offline   Reply With Quote
Old   June 9, 2009, 03:49
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
According to User Guide page 128 it is normal gradient. Learn to use documentation for such questions, it will be more usefull:-)
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   June 24, 2010, 16:09
Shoonya is on a distinguished road
Hello makaveli_lcf
You wrote that you had written your own code for dT/dn = h_ext / k_f * (T_ext - T) this kind of BC. I am trying to solve a problem which concerns the same BC you have talked in post #18. Could you please send me your code of that BC. I would be grateful to you.
thanks
Shoonya is offline   Reply With Quote
Old   October 6, 2010, 01:46
openfoam1 is on a distinguished road
the equation
valueFraction * U + (1 - valueFraction) * dU/dy = 0
is not dimensionally consistent !!
i think it should be
valueFraction * U + (1 - valueFraction) *dU= 0
which dU is only the velocity difference
any comments ?
thanks
openfoam1 is offline   Reply With Quote
Old   October 6, 2010, 17:48
Bin
That is a good post
dU is not dU/dn it is just the difference between internalField velocity and boundary velocity
because the equation must be dimensionally consistent
by the way , i verified it using simple mesh and icoFoam solver
thank you
Old   October 7, 2010, 03:31
It is not necessary to guess what is what. Just have a look at the source code, otherwise why do we need it)))
So, from mixedFvPatchField.C:
00142 template<class Type>
00143 void mixedFvPatchField<Type>::evaluate(const Pstream::commsTypes)
00144 {
00145     if (!this->updated())
00146     {
00147         this->updateCoeffs();
00148     }
00149
00150     Field<Type>::operator=
00151     (
00152         valueFraction_*refValue_
00153       +
00154         (1.0 - valueFraction_)*
00155         (
00156             this->patchInternalField()
00157           + refGrad_/this->patch().deltaCoeffs()
00158         )
00159     );
00160
00161     fvPatchField<Type>::evaluate();
00162 }
00163
00164
00165 template<class Type>
00166 tmp<Field<Type> > mixedFvPatchField<Type>::snGrad() const
00167 {
00168     return
00169         valueFraction_
00170        *(refValue_ - this->patchInternalField())
00171        *this->patch().deltaCoeffs()
00172       + (1.0 - valueFraction_)*refGrad_;
00173 }
That mean,
U_wall = valueFraction*U0 + (1 - valueFraction)*(U_nearwall + Grad0 * dn)
where U0 and Grad0 are our given reference values for boundary field and gradient at the wall. dn is the distance between center of the cell and the boundary face. Now it is possible to transform this condition in whatever form is necessary))) All gradients and matrix coefficients are calculated using this relation.
Good luck!
Best regards,
Old   February 17, 2011, 11:15
Raimonds Vilums
argonaut is on a distinguished road
To implement something like this
Originally Posted by makaveli_lcf View Post
T - T_ext - k_f /h_f * d(T)/dn = 0 (3)
you could use groovyBC from swak4foam in the similar manner like the following code:
rightWall
    type                   groovyBC;
    variables              "h_f=20.0;T_ext=20.0;k_f=0.2;";
    valueExpression     "T_ext";
    fractionExpression  "1.0/(1.0 + k_f/(mag(delta())*h_f))";
For explanation, see thread Mixed BC - heat transfer - laplacianFoam
argonaut is offline   Reply With Quote
Old   February 8, 2012, 14:31
Default Partial slip boundary
  #29
Kanarya is on a distinguished road
thank u in advance!
Kanarya is offline   Reply With Quote
Old   February 17, 2012, 12:26
Default ParticalSlip in OpenFOAM210
  #30
hi Foamers,
I am trying to compile particleSlip BC but it gives me error. can it be because of the version of OpenFoam because Alberto did code 2009 or 2010?can be the headers are different?
The error is:
Make/linux64GccDPOpt/particleSlipJohnsonJacksonFvPatchVectorField.o: In function `_GLOBAL__sub_I_particleSlipJohnsonJacksonFvPatchV ectorField.C':
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0xaf): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchConstructorTables()'
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0xcc): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >:atchConstructorTablePtr_'
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0xef): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructpatchMapperConstructorTables()'
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0x10f): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >:atchMapperConstructorTablePtr_'
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0x132): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::constructdictionaryConstructorTables()'
particleSlipJohnsonJacksonFvPatchVectorField.C.t ext.startup+0x152): undefined reference to `Foam::fvPatchField<Foam::Vector<double> >::dictionaryConstructorTablePtr_'
collect2: ld returned 1 exit status
someone can help me?
Thanks in advance
Old   February 27, 2012, 17:34
Unhappy particleSlipJohnsonJackson
  #31
Hi Foamers,
I would like to apply particleSlip BCs but I have following error and I could not find out the problem...please help me..
Create mesh for time = 0
Reading g
Reading transportProperties
--> FOAM FATAL ERROR:
request for dictionary kineticTheoryProperties from objectRegistry region0 failed
available objects of type dictionary are
4
fvSchemes
fvSolution
data
transportProperties
From function objectRegistry::lookupObject<Type>(const word&) const
in file /opt/openfoam201/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam::IOdictionary const& Foam:bjectRegistry::lookupObject<Foam::IOdiction ary>(Foam::word const&) const in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#3 Foam:articleSlipJohnsonJacksonFvPatchVectorField ::updateCoeffs() in "/home/recepkati/OpenFOAM/recepkati-2.0.1/platforms/linuxGccDPOpt/lib/libJohnsonJackson.so"
#4 Foam:artialSlipFvPatchField<Foam::Vector<double> >::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5 Foam:articleSlipJohnsonJacksonFvPatchVectorField:a rticleSlipJohnsonJacksonFvPatchVectorField(Foam::f vPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/home/recepkati/OpenFOAM/recepkati-2.0.1/platforms/linuxGccDPOpt/lib/libJohnsonJackson.so"
#6 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam:articleS lipJohnsonJacksonFvPatchVectorField>::New(Foam::fv Patch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/home/recepkati/OpenFOAM/recepkati-2.0.1/platforms/linuxGccDPOpt/lib/libJohnsonJackson.so"
#7 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam"
#8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam"
#9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam"
#10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam"
#11 at phaseModel.C:0
#12 Foam:haseModel:haseModel(Foam::fvMesh const&, Foam::dictionary const&, Foam::word const&) in "/home/recepkati/OpenFOAM/recepkati-2.0.1/platforms/linuxGccDPOpt/lib/libphaseModel.so"
Aborted
thanks in advance..
Old   February 28, 2012, 03:46
You need that dictionary for your solver.
Best regards,
Old   February 28, 2012, 06:22
  #33
Hi Alex,
thank you very much for your quick answer. I have already the directory there. I am using twoPhaseEulerFoam solver and I implement particleSlipJohnsonJackson BC in the model which is also from tutorials case "bed2".my file looks like:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
walls
type particleSlipJohnsonJackson;
specularityCoefficient 0.5;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (0 0 0);
frontAndBackPlanes
type empty;
I changed BC of the walls.
and I have the directory kineticTheoryProperties in the model.
thanks a lot again
Old   February 28, 2012, 06:25
That should be a file in "constant/" folder, see
bed2/constant/kineticTheoryProperties
in tutorial
Best regards,
Old   February 28, 2012, 06:33
  #35
Hi Alex,
yes I had a look to this file but I could not find the problem what I should add there?
I attached the code as well.
thank you very much and I appreciate your time to send me this suggestions.
recep
File Type: c particleSlipJohnsonJacksonFvPatchVectorField.C (5.8 KB, 34 views)
Old   February 28, 2012, 07:46
Do you have this file in your case folder?
Best regards,
Old   February 28, 2012, 07:48
Ok, if you look in your BC file
void particleSlipJohnsonJacksonFvPatchVectorField::upda teCoeffs()
if (updated())
return;
if ((specularityCoefficient_ < 0) || (specularityCoefficient_ > 1))
FatalErrorIn
"particleSlipJohnsonJacksonFvPatchScalarField: :"
"updateCoeffs()"
) << "The value of the specularity coefficient has to be between 0 and 1."
<< abort(FatalError);
const dictionary& transportProperties = db().lookupObject<IOdictionary>
"transportProperties"
const dictionary& kineticTheoryProperties = db().lookupObject<IOdictionary>
"kineticTheoryProperties"
so your BC looks for the dictionary kineticTheoryProperties in the memory,
but does not find.
Which solver do you use?
Best regards,
Old   February 28, 2012, 07:49
Default particleSlipJohnsonJackson
  #38
hi Alex,
I think you forget to say the name of the file, which file?
best regards and thanks again
recep
Old   February 28, 2012, 07:50
no, that which you send me
Best regards,
Old   February 28, 2012, 07:52
  #40
hi Alex
I am using twoPhaseEulerFoam.
yes, I understood the problem but I do not know how to modify it.
thanks
Recep
heat transfer, new bc
Boundary condition for UDS Tomik FLUENT 0 December 5, 2006 18:37
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 13:21
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 16:02
UDF boundary condition Jeff FLUENT 2 November 20, 2003 18:15
Boundary Condition in LES Zhang Tsiang Main CFD Forum 3 February 5, 2002 21:15
