Could anybody help the trouble of the modifying the U
Old   February 26, 2006, 16:49
Default Hi friend, I have a trouble
Guoxiang
liugx212 is on a distinguished road
Hi friend,
I have a trouble which I want to modify the U. I mean I want to keep the initial U to a new variable and after solver, I like to add this quatity to U again. But there are some errors. Could you please help me.
volScalarField Uin = UEqn.A();
U += Uin;
Errors:
icoFoam.C:120: error: no match for ˜operator+=U in ˜U += Uin"
/home/liu/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/GeometricField.C:1238: note: candidates are: void Foam::GeometricField<type,>::operator+=(const Foam::GeometricField<type,>&) [with Type = Foam::vector, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/home/liu/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/GeometricField.C:1238: note: void Foam::GeometricField<type,>::operator+=(const Foam::tmp<foam::geometricfield<type,> >&) [with Type = Foam::vector, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/home/liu/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/GeometricField.C:1238: note: void Foam::GeometricField<type,>::operator+=(const Foam::dimensioned<type>&) [with Type = Foam::vector, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
make: *** [Make/linuxGcc4Opt/icoFoam.o] Error 1
liugx212 is offline   Reply With Quote
Old   February 27, 2006, 06:03
Default In your code: volScalarFiel
Mattijs Janssens
mattijs is on a distinguished road
In your code:
volScalarField Uin = ...
in createFields.H:
volVectorField U(..)
You are trying to assign one (field of scalars) to the other (field of vectors)?
mattijs is offline   Reply With Quote
Old   February 27, 2006, 11:23
Default Hi Mattijs Janssens: Thanks
Guoxiang
Thanks. I mean that I want to keep my initial U to Uin and then add this Uin to new U (after end of the iteration). But the U is the vector. So I am not sure where define them and how to operating. Could you please give some help?
Thanks a lot.
Guoxiang
modifying under-relaxation factors pieizquierdo (miguel) FLUENT 7 July 30, 2011 09:05
Modifying an arc in GAMBIT? Jake FLUENT 0 April 1, 2008 17:23
Could anybody help the trouble of the modifying the U liugx212 OpenFOAM Running, Solving & CFD 0 February 26, 2006 17:48
Modifying solverslibraries Kaushik Balakrishnan (Balakrishnan) OpenFOAM Running, Solving & CFD 1 January 31, 2005 10:52
modifying commercial codes Richard Carroni Main CFD Forum 1 October 15, 1998 07:38
